guys running LC coils, drive line rubbing on gas tank skid?
Old 07-19-2013, 10:05 AM
chriso's Avatar
I'm getting this issue when making a sharp turn or flexing the truck out. LC 8 and 7.5 wraps. I'm thinking of bending the skid where it's rubbing or cutting part of it away with a sawzall. What is causing this?
Old 07-19-2013, 11:10 AM
jason in tn's Avatar
You need a pan hard drop to center that rear axle back up. The LC coils max out the flex of the pan hard bar and cause it to pull to the driver side.
Old 07-19-2013, 11:53 AM
chriso's Avatar
Honestly I don't trust the PH drop bracket to survive very long with the wheeling I do and as often as I wheel. Would it hurt to leave the PH bar in the stock location and just cut the part of the skid it is rubbing?
Old 07-19-2013, 02:25 PM
I don't think trimming the tank skid would hurt anything, I'm thinking about lengthening my bar a bit to fix mine.
Old 07-19-2013, 11:54 PM
KZN185W's Avatar
if you don't want the panhard drop bracket, you'll need the adjustable panhard rod (lateral control rod) to center your rear axle.
<img id="ums_img_tooltip" class="UMSRatingIcon">
Old 07-21-2013, 12:45 AM
chriso's Avatar
Will centering the axle fix the rub on the gas tank skid? Isn't this because of the angle of the pH bar? The drop bracket just doesn't seem very sturdy. I honestly might as well sell the LC coils and just order some OME rears for the cost of a adjustable PH bar.
Old 07-21-2013, 07:25 AM
Yes centering the axle should fix the problem. Its not so much the angle of the bar as the length. The adjustable one is spendy, but you have to remember when you change one thing it changes everything around it so you have to work thru all of it. Just part of modifying an automobile Lol. Good luck with what ever you decide.
Old 07-23-2013, 06:29 AM
chriso's Avatar
I marked the skid, removed it, and cut out a section with a grinder. I then flexed it out and got no rub, SO FAR. I'll be taking it out soon so we will see.
Yont283
09-23-2022 08:06 PM
zd92655
03-06-2022 12:58 PM
crazypaint
06-23-2015 03:27 AM
slider417
06-22-2015 10:18 AM
westbound
06-07-2002 03:30 PM
Quick Reply: guys running LC coils, drive line rubbing on gas tank skid?
