Guess the lightbulbs (please help)
Old 11-09-2008, 01:44 PM
freeridethis206's Avatar
Hey there,
Took these bulbs out of my 2000 limited today and i have no clue what sizes they are. i looked on superbrightleds.com but didn't find anything.
the bulbs from left to right came from
-etc backlight
-climate control backlight (limited so it's the electronic one)
rear power window control backlight
thanks for any help!
for scale, the longest one is just shy of 1in
Old 11-09-2008, 05:58 PM
anyone!??
Old 11-09-2008, 06:11 PM
littlecommando's Avatar
take them to a advanced auto/auto zone/o'riley/local auto place and match it with ones in package or have people there help you figure out which one it is, then write down the number off the package
Old 11-09-2008, 07:30 PM
schmooot's Avatar
just pocket a bunch next time you are at the wrecker...they will be at least 3 or 4 bux each new if you can find them...you may have to go to toyota for them
Old 11-09-2008, 07:40 PM
Godzilla's Avatar
OK so are you just trying to replace them with LED's or just replacing them with stock? If stock these are the numbers for the climate control :
81850-35020 LCD Display Bulb
81850-35030 Background bulb for the rotary/function buttons
Numbers taken from https://www.yotatech.com/forums/f127...acement-70183/
If it is for LED, search through all the relamp threads in this subforum
Old 11-09-2008, 10:37 PM
Fo_SheeZy's Avatar
They are all four neo wedges, Type A & B, get them here: http://autolumination.com/74.htm
Here's a thread with a ton of useful info:
https://www.yotatech.com/forums/f2/g...ghting-117226/
After they are installed:
Old 11-10-2008, 03:30 AM
DYNNOMMYTE's Avatar
The larger of the bulbs is a peanut bulb with a condom on it.
You can get different colours from aftermarket parts stores, even Canadian Tire has a selection of coloured bulbs ( blue and red, me thinks )
the smaller bulbs are also available at your local parts store, you just have to remove them from the plastic housing.
Old 11-10-2008, 04:25 PM
hey, so im looking on autolumination and i only can definitively identify 2, the white one is neowedge B and the brown one is neowedge A, the other two are still a mystery.
I called my local dealer and he said that all of the bulbs for the climate control were toyota's proprietary bulb, although the white one i id'ed as a neowedge... any other ideas for the two remaining green ones?
LittleUgly
15
01-02-2020 01:30 PM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
hiluxinargentina
09-30-2015 05:51 PM
JookUpVandetti
09-30-2015 08:58 AM
yoterr
09-15-2015 03:47 PM
Quick Reply: Guess the lightbulbs (please help)
