GSGALLANT or others - after market cruise
Came across this (old) thread doing some searching:
https://www.yotatech.com/forums/f160...cifics-181098/
That picture of the TB there looks like it has an aftermarket cruise control installed. I think I have the same kit but I haven't got a straight pull on the cruise cable yet. I'm wondering is you could post a pic of the bracket mounting with the square hole in it that the cruise cable passes through - and how you mounted the cruise to the T-Bar; I used the loop cable but had to dremel out some plastic on the TB pulley.
Thanks, I re-did my mounting bracket, I guess it doesn't look too bad. At least it pulls in a straight line like yours..see attached.
You do have the Global Cruise from Rostra don't you? How has it worked out? Looks like you've had it for a while, I hope I made a good investment.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
Tcsdef
09-07-2015 11:17 PM
