Grinding Noise Shortly After Startup
This is my first post to the forum and I have spent some considerable time searching through past posts to find an answer to this problem so I apologize if it has been covered.
I have a '98 4Runner Limited 4x4 Auto with the 3.4 and close to 150k miles. On a cold start or after the truck has been sitting for a while, there is a grinding noise that seems to be coming from the front left. It only happens when I pull forward (out of a parking spot). I cannot seem to replicate it when it is in park. I have tried turning the wheel back and forth. Also, if I put the truck in D and inch forward it does not happen. It only occurs when I go ahead and pull out.
Now the sound:
It only lasts about 1 second and it almost sounds like a ratchet tightening up. It is definitely in the front of the truck and possibly higher up in the engine bay.
My first thought was power steering and when I checked the fluid it was a little low. I topped it off but the sound still happens. The odd thing is that it only happens when you are in D AND pulling forward. You can be in P or in D and sitting still and it will not happen.
Any thoughts?
Thanks for the help.
Now the sound:
Any thoughts?
ABS light is on, but that was expected. The ABS actually kicked in when I was going over a patch of small, rapid bumps. I could really hear the pump and it did not sound normal. It spooked me enough that I think I will leave it disabled until I can have the pump checked out.
genuinegemini
08-03-2015 04:56 PM
mengquis
07-13-2015 10:39 AM
