| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Grey wire mod help!
__________________
1999 4runner Limited 4x4 - E Locker - SS #1.51 Kit - King 2.5" Coilovers - 285 Mickey Thompson Baja MTZ's - Stubbs Sliders - Alpine 9883 Deck - Shrockworks Front Bumper |
#2 (permalink) |
whats the grey wire mod and why do it?
#3 (permalink) |
im pretty sure the paint does have to be sanded off. i didnt do that mod but i think the abs light come on
__________________
87 4Runner SR5 - some spacer lift with cranked torsion bars - 31x10.50/15 BFG Mud Terrain KM2 (amazing tires!) 99 4Runner SR5 Highlander-auto - K&N filter, removed intake elbow, open air box, deckplate mod - 265/75/R16 BFG MT's on stock 5 star's - raised rear diff breather 2003 Mach 1 -full bolt ons, 4.10 gears, tuned by Excessive Motorsports; 307 hp, 326 tq |
#4 (permalink) |
Yes, when you engage the rear locker, your abs light should come on and the RR Lock light should stay on steady. Yes if you can't find a ground around that area without paint, then you need to sand some off so the terminal makes good contact.
whats the grey wire mod and why do it? The grey wire mod allows you to engage your rear locker, (if you have one) without being in 4lo...so you can pretty much engage it whenever you want, 4hi, 2hi, whatever..
__________________
2006 Tacoma SR5 - Stock for now 2000 4Runner Limited 16x8 Pro Comp Steelies wrapped in 285/75R16 Pro Comp M/T'S~RB 2" Body Lift~SS 1.2 Lift~1st Gen Roll Bar~Surco Safari Rack~ Trail Gear Sliders~Deckplate Mod w/ True Flow~Satoshi Grille~Hayden 1678 Aux Cooler~Safari Snorkel and a bunch of other crap..... |
#5 (permalink) |
alright.
ill try that. thanks.
__________________
#6 (permalink) |
another note of interest, if your light is flashing, your *mod* is working. your mod is telling the locker to engage. the light is flashing because the locker can't engage. which this happens, you should try driving forward some and then backwards some and, if necessary, doing a "S" shape path. you need everything in the differential to line up properly for it to engage. that is normal behavior.
__________________
-David 2000 Taco TRD Access Cab v6 | 5spd | 33" BFG A/Ts | 33" PC Mud Terrains | OME 882's | Bilstein HD struts front | Rancho shocks rear | Chevy 63" leaf spring swap | Custom sliders | Custom front bumper |3" BL | U-Bolt flip | Flowmaster exhaust | Kenwood Speakers | Grey Wire Mod | Aux. Reverse Lights | Deckplate Mod | Lots of lights Pictures |
#7 (permalink) |
i tried all that for about 10 minutes.
still no solid light or abs light.
__________________
#8 (permalink) |
either sand your ground (bad grounds can do funny things) or reverse the mod and see how it acts. just temporarily connect the wire back to how it was before you cut it.
__________________
#9 (permalink) |
i just sanded the ground to the metal and tried that.
that didnt work.
__________________
#10 (permalink) |
reconnect it how it was and see how it acts.
__________________
#11 (permalink) |
does the gauge of wire have to be the same as the stock one.
__________________
#12 (permalink) |
i just put it back stock and it works fine.
__________________
#13 (permalink) |
gauge needs to be the same or bigger (fatter wire), definitely not smaller wire. what side did you ground?
__________________
#14 (permalink) |
the one from the ecu.
i got the right ground. maybe its the sauterless connectors.
__________________
#15 (permalink) |
try that but it shouldnt be. a standard butt connector should work fine
__________________
#16 (permalink) |
Are you grounding the right side of the wire? You need to ground out the wire from the connector. Are you stripping the wire back far enough?
__________________
#17 (permalink) |
im grounding the wire coming from the bottom of the ecu.
should i ground the other one?
__________________
#18 (permalink) |
you splice into the end coming FROM the white connector
__________________
#19 (permalink) |
well that solves my problems.
hahahahah.
__________________
#20 (permalink) |
lol...
__________________
#21 (permalink) |
That's pretty funny.
I still need to do this on my 98.
__________________
1998 4runner. Flat Olive Drab with World Rally blue badge and flat black accents. TRD e-locker, BFG mud terrains, in need of SAS. 2007 Satin White Pearl STi 2006 WRX - Totalled |
#22 (permalink) |
so i take it it worked?
__________________
#23 (permalink) |
yep.
works like a champ.
__________________
#24 (permalink) |
ahh yes i made a thread just like this also i guess its the blue/red wire mod for the 4runners
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 97 SR5, 2.7 L ISR questions and Grey Wire mod question | Kintore | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 07-12-2007 12:14 PM |
| Grey Wire mod, Mystery wire? | 2KTacoma | General Electrical & Lighting Related Topics | 2 | 11-28-2006 09:55 AM |
| grey wire locker mod? | jjrgr21 | 95.5-2004 Tacomas & 96-2002 4Runners | 26 | 09-18-2006 11:32 PM |
| Grey wire mod question | HOJU | 95.5-2004 Tacomas & 96-2002 4Runners | 16 | 05-18-2006 11:52 PM |
| grey wire mod | metalhed | Off Topic Talk | 1 | 06-04-2004 01:37 AM |
