Sign in using an external account
| 95.5-2004 Tacomas & 96-2002 4Runners 4th gen pickups and 3rd gen 4Runners |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
Gremlins? or Did I really just kill my truck??
#2 (permalink) |
Personal
Sales Rating: (0)
how does the tranny dipstick look ?
transmission jerky, could be coolant in transmission. when oil and water mix and heat up in the engine jacket it makes all sorts of odd noise and that stuff gurgles around and temps go nuts and ....well verify it isn't water in tranny right away any previous water or temp issue can cause an 'almost ready to fail' tranny cooler to fail. so this could have been precipitated by bad thermostat or other cooling issue. but you don't know till you grab the atf dipstick and look at it Last edited by BigBallsMcFalls; 04-23-2010 at 08:48 AM. |
#3 (permalink) |
Personal
Sales Rating: (0)
[OP]
Good call, fluid on tranny dipstick looks like strawberry milkshake. What next? It is possible that I damaged the engine or do you think the condition when it warms is a result of the coolant/tranny fluid mix?
#4 (permalink) | |
Personal
Sales Rating: (0)
Quote:
No you didn't damage the engine I bet. those are unkillable but the tranny may be on it's way out. or dead. 1) do NOT drive it 2) replace radiator with OEM, or go with new rad + external tranny cooler 3) replace thermostat 4) have a professional cooling system flush where an added chemical will remove hidden oils. do this twice, then fill 3rd time with Toyota red and a bit of the oil removing chemical 5) have your transmission professionally computer flushed: a LOT drop pan, pour in new ATF until the stuff that dribbles out is red only replace filter, pan, and computer power flushed with at least 3 times, until it is pure red. this is gonna be about 45 quarts total 6) Your tranny may not survive ! so plan on $1700 tranny rebuild if it ends up slipping, or find a fresh one in a junkyard somewhere ----------- do it yourself, maybe 300 bucks parts and oils and juices. hard to really scour that transmission by yourself though.... pay a shop, 600-800 bucks. and that is if your tranny didn't get damaged too bad. ------- water is extremely toxic to the automatic transmission, that is your biggest worry. will the bands and clutch packs and solenoids survive ? they MIGHT....it is guesswork. it sounds like you drove it a bit, but easy... while the problem existed. it may survive. ---- search the forums, this has happened a lot, and I had a shop fix me up. so far, so good. Last edited by BigBallsMcFalls; 04-23-2010 at 11:33 AM. |
#5 (permalink) |
Personal
Sales Rating: (0)
Sorry to see another one go down. Yeah its an expensive mess to clean up. Many have had this problem, you're now a member of the strawberry milkshake club.
Some threads you'll want to read: http://home.centurytel.net/stevenjac...sh/tranny.html http://www.yotatech.com/f2/radiator-...-fluid-116812/ http://www.yotatech.com/f2/99-4runne...-trans-117503/ http://www.yotatech.com/f2/tranny-cooler-burst-126886/ http://www.yotatech.com/f2/bypass-oe...cooler-126953/ http://www.yotatech.com/f2/my-milksh...y-yard-207553/ One tip is do most of your tranny flushing with cheap ATF, then switch to the good stuff near the end of it all.
__________________
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG KM2, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, TJM T-17, Warn m8000. Last edited by mt_goat; 04-23-2010 at 11:42 AM. |
#6 (permalink) |
Personal
Sales Rating: (0)
Damn--that sucks--gotta love manual tranny....
I thought for sure the HG was going to be blown-- Good luck
__________________
Yes, I said "country." America really is a nation, but you couldn't convince those who lead the Democratic and Republican Parties of that. Both parties now see America as nothing more than an economy, a marketplace, and not a sovereign nation. They don't see you and me as citizens of this great nation; they see us as units of labor, consumers and taxpayers. Yes, I am here to collect my 238$ worth of stock from AIG. "What do you mean a free market economy doesnt apply to the rich?" |
#7 (permalink) |
Personal
Sales Rating: (0)
[OP]
Ok, so I got a new radiator, ordered a trans filter, and have coolant and atf ready to go. I don't get the filter till friday, should I flush the trans and coolant and then drop the pan on friday. I'm going out of town and don't want it to sit with that stuff in there. In the Tranny Flush write-up, he changes the filter and drops the pan, THEN flushes the fluid. Does it make sense to get all of the bad stuff out today, then go in on Friday and change out the filter, etc...
#8 (permalink) | |
Personal
Sales Rating: (0)
Quote:
no the filter may have a great big blob of foam stuck inside it, wasting effort it makes sense to drop the pan and filter now and let the thing drip dry if you are gonna have it sit and then pour in ATF via fill tube (dipstick) until what drips out is rock solid clean now you can wait....but time is crucial. that water/foam is eating your clutch packs Then replace pan and filter, gasket and bolt it up, and then put it on jackstands, start engine, and start the the process of flowing 30 quarts of new ATF through it via the cooling lines, big old catch bucket, and fill tube, until it is 100% no foam coming out. run through the gears a bit, all positions, keep replacing new ATF. you should use up 30 or 40 quarts just as waste. makes even more sense to have a transmission machine do it for you, it can operate the solenoids and pump fluid through it all day long. Last edited by BigBallsMcFalls; 04-28-2010 at 09:07 AM. |
#9 (permalink) |
Personal
Sales Rating: (0)
I'm a little worried about your engine because it got hot for an unknown amount of time, and that happened more than once. I hate to say it, but usually that will cause some form of damage whether it be to your valves, heads, gaskets, etc... I hope I'm wrong but I would save up some $$ now for a possible rebuild in the not-so-distant future.
__________________
'97 4Runner SR5 3.4L 4x4 - Lifted on 35s, Geared, Dual Locked, and Armored '98 Tacoma Regular Cab 2.7L 5-speed 4x4 - Bone Stock DD
#10 (permalink) | |
Personal
Sales Rating: (0)
Quote:
yeah, the additional pinging and power loss symptoms could be -bad- it might have been the transmission locking up on you, transmission sounds or it could have been the pistons seizing or trying to seize definitely keep taxi money on you anytime from now on, out driving the rig, once you get it all fixed. transmission or other could just let go on you |
#11 (permalink) |
Personal
Sales Rating: (0)
[OP]
Engine might have gotten hot for a number of minutes at most. The strange thing was I couldn't get any heat to come out.
As of right now I have the new radiator installed, but not hooked up, and the pan drained and bolts removed but the pan still attached. I have to go to work in a few and tomorrow am I'm leaving to go out of town. Would it make sense to add some fluid and run it for a few, then drain it out again? Or should I just leave it as is? It's gonna have to wait until next week to get worked on, I'm outta time. |
#12 (permalink) |
Personal
Sales Rating: (0)
Unfortunately a few minutes is enough to warp a head and/or blow a head gasket. The fact that you have no heat would lead me to believe something like this may be your issue.
__________________
#13 (permalink) |
Personal
Sales Rating: (0)
Its pretty common for the heat to not work when the coolant level is low. The air in the system forms a block near the heater hoses.
__________________
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG KM2, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, TJM T-17, Warn m8000. |
| Tags |
| milkshake, strawberry, survived, toyota, transmission |
