Great Hi-Lift tip..
Old 03-18-2003, 07:45 PM
Firefyter-Emt's Avatar
Great Hi-Lift tip..
We all should know about the pin for the base, well here is a new one.. I had to use my handle as a breaker bar on day and lost that stupid cotter pin that holds it in place.. I could not find one that worked good and stayed in place.. So I improved it!! I drilled the hole slightly bigger and ran a 6mm tap through the hole.. Now I have a nice stainless steel 6mm pan head screw in place.. It can not fall out, and can be removed easy again and again... Looks a lot better too!
Old 03-18-2003, 08:32 PM
minidisc8's Avatar
Good call. I might try something like that because I hate how my handle rattles around so much.
Old 03-18-2003, 09:00 PM
It will not help the rattle.. all I did was to change the cotter in to a bolt (with a threaded hole in the handle) I think I am going to buy an allan bolt for it (I think the smaller rounded head will look a lot better)
For the rattle, try pipe insulation slid over the handle for storage
theking11863
03-19-2016 09:36 PM
BeMiceElf
10-10-2015 09:40 PM
09-04-2015 09:27 AM
genuinegemini
08-03-2015 04:56 PM
Nailit69
Diesel Swaps
07-21-2015 05:28 PM
Quick Reply: Great Hi-Lift tip..
