Grease leaking from front drive shaft, help
Old 08-31-2004, 04:32 PM
Guest
Yoter's Avatar
For quite a while now my front drive shaft has oozed grease from where the shaft splines together. I just keep greasing it up but it sprays it all over down there. Do I need to replace a seal or the entire shaft?
Old 09-04-2004, 07:26 AM
Guest
Yoter's Avatar
Bump?
Old 09-04-2004, 07:29 AM
shiftless89's Avatar
You probably have to much grease in there! the seal is designed to keep dirt out, but not realy to keep grease in! one or at most 2 pumps on the grease gun should suffice, there should only be a thin film on the splines to lubricate them.
Good luck!
Mike
Old 09-04-2004, 07:30 AM
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
Are you talking about your CV boots?
http://www.diynet.com/diy/ab_suspens...277530,00.html
Old 09-04-2004, 07:31 AM
Guest
Yoter's Avatar
Good luck!
Mike
thanks
Old 09-04-2004, 07:32 AM
Rick F.'s Avatar
OOPS! DRIVE shaft... Me bad...
Jdgarrison
10-01-2015 05:22 PM
camdenbuck
07-07-2015 07:33 AM
TNRunner88
07-01-2015 08:00 PM
Gamble_STi
07-01-2015 12:51 PM
Mr.Black
06-21-2015 10:17 AM
Quick Reply: Grease leaking from front drive shaft, help
