Grease Fittings/Fuel Filter Questions
Got 2 questions on a 01 3.4 Taco.
1) I noticed grease fittings at some of the driveshaft joints. Do I need to look at greasing these myself and if so how often, how much and what kinda grease you recommend. Besides these are there anymore on the truck. Greasing is not a problem for me other than the fact ive only done it on industrial machines and bearings with lithium grease.
2) The fuel filter replacement. Ive noticed most places want an arm and a leg to replace one. I paid to have it done on my ford because you needed special fuel line tools that didnt work worth a crap but the taco filter looks like you just unbolt it from the bracket then loosen the bolts on both sides that connect the lines, is this correct?
thanks
thanks
1)Do I need to look at greasing these myself and if so how often, how much and what kinda grease you recommend. Besides these are there anymore on the truck.
2)the taco filter looks like you just unbolt it from the bracket then loosen the bolts on both sides that connect the lines, is this correct?
If you don't already have one, pick up a Haynes or Chilton repair manual and it will detail both of these jobs for you.
EDIT: Damn. Too slow. toy283 beat me to it.
Thanks guys, I saw the fittings on both driveshafts so thats what made me think they needed to be done. I like the idea of greasing them every 5k when I do my oil also. How many pumps do they take or is it obvious.
pyramid
07-30-2015 10:05 AM
Toyvana
07-29-2015 10:47 PM
