Greasable Shackles...etc...
Old 01-19-2004, 09:09 AM
Serith's Avatar
I have greasable shackles and drivelines...etc... pretty much anything that moves. I have a few questions about them...
1. How do you know how much grease to add? I've heard adding too much can hurt them.
2. How often do you need to add grease?
3. Is adding too much grease going to hurt something? in drivelines or shackles?
Old 01-19-2004, 03:13 PM
tenfourtyeight's Avatar
Bump.
I'm curious about this myself.
Old 01-19-2004, 08:48 PM
Serith's Avatar
Come on...someone has to know? anyone? Nobody has these?
Old 01-19-2004, 10:38 PM
EWAYota's Avatar
Old 01-20-2004, 05:05 AM
CTB
CTB's Avatar
On my driveshafts and joints, I pump in new grease until i start seeing the old grease leaking/oozing out from the joint.
On my front suspension parts, I just put 4-5 pumps in and make sure the boots surrounding the joins feel fairly stiff.
Old 01-20-2004, 07:16 AM
Guest
foxtrapper's Avatar
I personally lube everything each oil change. Just a quick pump of the handle to each of the grease fittings, and a shot of silicone to the various rubber bushings.
Overgreasing is an issue for things like wheel bearings, not shackles and ball joints. On the latter, it's just an issue of mess. On wheel bearings, you can overheat and destroy the bearings.
Old 01-20-2004, 08:45 AM
toy283's Avatar
I wouldn't worry about over-greasing suspension components. Just shoot grease in until some starts to seep out then wipe off the excess.
nvdesertrunner
05-11-2020 08:18 PM
vikinghug
06-14-2016 08:10 PM
Scottcrb
03-03-2016 11:57 AM
rednecktoyotahunter
11-18-2015 08:58 AM
Shaun Crystal Gomban
08-02-2015 08:00 PM
Quick Reply: Greasable Shackles...etc...
