GPS mount on the cheap - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-01-2005, 09:04 PM   #1 (permalink)
Flamedx4's Avatar
I just made myself a mount for my GPS that will work in both of my trucks.
I used a piece of 1/8" x 1" aluminum flat bar that I had laying around. I used the dremel to cut off and then grind smooth 4 small screws that fit into the little holes (in this particular unit - yours may vary) and bent the flat bar to cradle the unit the way the $60 factory brackets do. Note that the screws do NOT screw into the GPS, after I screwed them through the aluminum I ground them off so they are just pegs.
Then I cut off a plastic travel mug. I cut a wood plug to fit into the top of it and screwed the "mug" to it, then screwed the aluminum bracket to it.
Then I painted the whole thing flat black.
Then I wrapped the "mug" with layers of foam tape (camper tape I had laying around, cut narrower with a razor blade) to make it multiple sized and snug fitting in the cup holders of both my trucks. (Didn't want it bouncing around.) I then wrapped the foam tape with black electrical tape so it would last longer.
It fits snug in the cupholder in the Yota and the F150. I use a 12v cord. Works great. I also have a magnetic external antenna but it works fine without it.
Cost: $0.00 I had everything I needed already. (As long as the GF doesn't go looking for her purple travel mug...)
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil
Flamedx4 is offline
Old 08-02-2005, 07:36 AM   #2 (permalink)
Sponsoring Member
midiwall's Avatar
Very nice!
__________________
~ Mark
'96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams
midiwall is offline
Old 08-02-2005, 10:11 AM   #3 (permalink)
geneius's Avatar
Awesome! I may use your idea for other applications...if you dont' mind.
Congratulations, you have won the McGuyver award. Expect this in the mail sometime soon:
__________________
Gene's 95 LTD 4Runner
Downey HD Coils, Spacers & T-Bars (3" Lift) | ProComp ES3000 Shocks | Warn Premium Hubs | 15x8 Black Rock Crawler Rims
BFG AT/KO 33x12.5x15 | K&N Drop-In | 4.88 Gears (stock) | ProComp ES2000 SS | Idler Arm Gusset | SS Braided Brake Lines
ISR Mod | Diff Breather | Hella 500s | Cobra 75WX ST | FireStik Firefly | Tranny Cooler | All Pro Off Road Sliders | More Later...
geneius is offline
Old 08-02-2005, 12:24 PM   #4 (permalink)
Flamedx4's Avatar
Had to find some use for that cupholder - it's useless for drinks...
__________________
Flamedx4 is offline
Old 08-05-2005, 02:19 PM   #5 (permalink)
I had gotten a crappy cell phone holder, that slipped in a cup holder. I then got the correct RAM mount for my GPS and an extra ball mount, one is on my four wheeler thei other was bolter to the cup holder mount. Ram mounts work great!
SLG
BikKat is offline
Tags
4runner, 4wheeler, aluminum, antenna, cheap, custom, f150, gps, homemade, making, mount, mounting, mounts, truck, wheeler
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Need quick help deciding on cheap gps 4rnr GPS & Communication 10 12-24-2006 10:01 AM
Pic's of My GPS & mount Noliwan GPS & Communication 19 09-11-2005 10:12 AM
Good/cheap GPS UNR.Grad GPS & Communication 12 09-02-2005 09:26 PM
GPS V Mount Mod!!!!! Plamar 95.5-2004 Tacomas & 96-2002 4Runners 16 06-09-2003 09:04 PM
Garvin Roof Rack with custom Hi-lift mount and custom RAM GPS Mount Installed transalper 95.5-2004 Tacomas & 96-2002 4Runners 10 01-17-2003 01:09 PM
2009 InternetBrands, Inc.
