got a problem from the wreck
so my truck still isn't fixed. i have replaced the upper control arm and ball joint, but the tire is still rubbing on turns and the drivers side front tire is two inches farther back than the other side. i will try and post pics in the next hakf hour, but any suggestions to why this is?
best bet is to take it to an alignment shop where they can check the geometry of things. They should be able to tell you exactly what is bent. I'd do this if you arent able to tell just on a visual inspection.
