Got my arms back on! :)
After about 4 years of the Trailmaster lift and the funky 2nd struts they use to replace the upper A-arms, I ended up getting some Fabtech spindles and put the upper A-arms back! I'm stoked. The drive is already much tighter, and now I don't have to worry about popping the mounts off from the old setup (Done it before).
They are super beefy and weigh in at 55lbs each (the spindles).
DesertCamper --- I had my mechanic friend down the street go over the bushings and ball joints with me, and we did some movement tests to find out that everything was fine. I mean, yeah I could use some new parts since they are old, but they are not failing. I think the main problem was my old lift setup. It was janky and caused a lot of movement. Hopefully they will just align my truck now.
awpsome - look at my sig-line. I have a huge writeup and information on that link.
Blackdog: I bought them used from TTORA. You can buy them for about $300-400 each from 4wheel parts or Offroad warehouse. :/
JamesD: No I hadn't had my bearings replaced. I'm still uncertain to why the shaft broke. I contacted Toyota, and they didn't have any answers or information. It was a scary situation due to the fact I was driving at about 45 mph when it broke and pulled out of the housing.
That is awesome! I saw about your fix on TTORA, and wanted to get some input from you? Im looking into getting these knuckles (before I weld #2 crossmemebr back!) I hate my POS TM lift, was going back to stock, but this may be the way to go?
I bought my truck in San Diego BTW
Has King CO's in front w/Bilstein 5125's rear
Its going quite well....
[IMG]http://img.photobucket.com/albums/v25/Guyster/crash2_10_2010027
.jpg[/IMG]
Kit:
Man, I "hope" its straight! lol
Just back from alignment. Heres a complete pic. Same wheels, no spacers, 285's instead of 35's. Best off, no more DB kit
Hytenor: Align specs before
Align specs after:
.jpg[/IMG]
Kit:
Align specs after:
Kluch8651
07-09-2015 10:39 AM
