| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Got my 3rds
__________________
UZswap.com A site dedicated to sharing info for swapping the Toyota/ Lexus UZ (V8) engines into Toyota Trucks and 4Runners. My 4Runner 1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys, low lift, hacked fenders, tubbed firewall, custom armor TOOLandFAB.com A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion |
#2 (permalink) |
OK, looks like I got stuff I can't just bolt in.
![]() The rear diff does not have a speed sensor for the ABS and the front doesn't have ADD. I'm sure I need a different rear 3rd, but can I swap over the ADD stuff to the front housing, or should I go to a yard and see if they'll switch with me? I wanted to use parts that would make swapping these in a fairly quick bolt up procedure.
__________________
#3 (permalink) | |
Quote:
anyway, did you get lockers installed in those?
__________________
Front: 4.88's w/ ARB Locker Rear: 4.88's w/ ARB Locker Lift: Suspension - F: Sway-A-Way Coilovers; R: OME Coils/Shocks Body - 2" HDPE Pucks w/ higher strength bolts Recovery: TJM T15 Bull Bumper w/ Warn M8000 Winch Lighting: Lightforce Striker 170's Multimedia: Kenwood DNX5120 DVD/GPS/USB/iPod/SAT Sound: Focal 165A1 Component Front w/ Focal 130CA1 Rear Infiniti Kappa Perfect 10.1 Sub 500W RMS amp for fronts and rears; 500W RMS amp for sub Power: Optima Blue Top 1400 Watt Power Inverter |
#4 (permalink) |
If you have no hole in the rear for the ABS, that is a problem
The front is great though. Many people fit the short side tube on to eliminate the ADD sleeve all together. You can either install that front as it is or swap the side tube to your current diff. Think of it as moving up in the world. |
#5 (permalink) |
Are you going with ARB front and rear?
#6 (permalink) |
Not from Randy's
![]() No lockers yet. I'm getting them installed locally. I bought the 3rds from a POR member that's local here. I was so excited I found someone with 3rds to sell that I didn't check about the ADD and or the ABS snesor plug on the housing for the rear. Am I right about the diffs not being something I can use? I can't believe I didn't look for that stuff...
__________________
#7 (permalink) |
To reiterate.
Rear=NO Front=YES as is or YES if you swap the tube. The diff can be regeared with or without the tube on and the tube from the diff on your truck can be swapped to the third that is in the pic. |
#8 (permalink) |
You're throwing those in without lockers?! I don't get it.
#9 (permalink) | |
Quote:
__________________
#10 (permalink) |
I believe he is getting lockers installed...locally. Not going with Randy's...very wise
Aaron
__________________
2007 Tacoma DC 4WD TRD In Germany. Haven't been here since I got rid of the last Runner in 2005. Glad to be back in 'yota's. |
#11 (permalink) | |
Quote:
I lurnt the hard way.
__________________
#12 (permalink) | |
Quote:
![]() 4.10's with auto and 33's would not be a good combo. I already have 4.88's but its too peppy for me. ![]() I'm going to see if I can swap a yard for something a little more suitable. I'm getting the overhaul kit from Randy's (Internet special) for $389 which I believe is front and rear gears, bearings and all that other crap. ARB Lockers from Wolfpack TLC. I already have an Extremeaire compressor.
__________________
#13 (permalink) | |
Quote:
__________________
#14 (permalink) | |
Quote:
![]() Oh drat, I'm confused now.. Oh whatever shall I do??
__________________
#15 (permalink) |
Good news, I can return them and get my $$ back. Just heard from the seller. Wahoo!!
__________________
#16 (permalink) |
Mike,
You're just getting to be quite the smart-ass, aren't you? A little more sarcasm and I'll actually be able to understand what you're saying.
__________________
____________________ Greg 93 4x4 pickup |
#17 (permalink) | |
Quote:
__________________
-Chris If you can't explain it simply, you don't understand it well enough. Click here to search! My Website |
#18 (permalink) |
Just a random point of information; there is no such thing as a V6 front IFS diff. They're all the same. Only the rears are different.
__________________
Dave Currently own no Toyotas :( |
#19 (permalink) | |
Quote:
__________________
#20 (permalink) | |
Quote:
__________________
-Glenn- |
#21 (permalink) | |
Quote:
__________________
#22 (permalink) | |
Quote:
__________________
-Glenn- |
#23 (permalink) | |
Quote:
__________________
#24 (permalink) | |
Quote:
You've all got me reconsidering about returning them both...
__________________
#25 (permalink) | |
Quote:
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Looking for 3rds and Buckets | 91ToyTrck | The Classifieds GraveYard | 5 | 08-02-2007 08:12 AM |
| interchangeable 3rds | 88yotatruck | 84-85 Trucks & 4Runners | 4 | 12-21-2005 06:52 AM |
| interchangeable 3rds | 88yotatruck | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 12-15-2005 05:24 AM |
| can i just swap out 3rds | runnerboy97 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 09-01-2004 05:59 PM |
| 3rds | grpape | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 10-17-2003 11:20 PM |
