| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Got Low Profile Upper Bumpstops!
__________________
1997 Toyota 4Runner, 3.4L (5VZ-FE), 5-Speed (R150F), 4WD, 4.10's, 33's 1998 Toyota 4Runner, 3.4L (5VZ-FE), 5-Speed (R150F), 4WD, 4.10's, 33's 1991 Toyota 4Runner 4 Door, 3.4l (5VZ-FE), 5-Speed (R150F), 4WD, 32's, 4.10's |
#2 (permalink) |
Well install them and let us know how they work! You should do some sort of test involving the stock setup compared to the new bumpstops. I'm going to do them very soon. Don't forget to do this
#3 (permalink) | |
Quote:
__________________
Click here to buy rock crawling stickers and shirts |
#4 (permalink) | |
Quote:
Jason is right. I'm yet to see a truck that can tolerate the spacers with low pro upper bumpstops. Given the angle of the upper arm, minimal gains are to be had even if you find you can make it work. Shocks will likely over extend beyond the point of shimming too. You can however use low pro lower stops. Should you decide to experiment, do this. Whith the spacers on, and at full droop, lock the hub and spin it. Do this with the tires turned full each way too. It should have no binding and the suspension should not move sympathetically as the joint spins. First things you'll notice if you are pushing them too far is the suspension will move up and down as each of the three balls takes turns pivoting and binding. Frank |
#5 (permalink) |
I am keeping the stock uppers, I got 2 LP pairs to replace the 2 stock lowers on each side.
Thanks
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Low Profile Polyurethane Bumpstops | Robinhood150 | Off Road Enhancements | 0 | 01-07-2006 07:12 PM |
| Low profile bumpstops. Both or only compression? | Blizzard | Offroad Tech | 4 | 06-22-2005 12:02 PM |
| Where can I get some low profile bumpstops? | '94Runner4WD | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 05-12-2004 08:39 PM |
| Low profile bumpstops | fooddude | Offroad Tech | 17 | 12-26-2003 08:59 AM |
