got her running great now a code 25
After all that idling like ลลลล i replaced the intake manifold gasket adn fixed teh crack in the manifold. I also had codes for air temp sensor and AFM so i was able to swap my filter box with a 93 yota 2wd (has a rod knock so it my new parts truck ) the part numbers matched up and its been running and idling great since i did so. But now every once in a while i get a code 25 (which i didnt get before) so im wondering should i maybe turn up the idle mixture a bit? I only have a set of headers on my truck so idk if its performance or the 2wd ran a little leaner.
Any input would be great
ps i have a 94 hilux 22re
Originally Posted by dogdenii
CHECK your grounds. If it's intermittent, this is probably the case.
skoti89
07-06-2015 07:45 PM
Jnkml
07-06-2015 01:20 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
