Got the cutting wheel out, trimmed the fenders
I noticed a very slight rub, I had taken the pinch weld out but notice the tires hit, so out came the cutting wheel, some urethane primer and flat black paint.
I snipped it out squared it off, primed and painted the freshly cut area flat black. I think it looks better, making the tires look less stuffed it, also has provided the clearance I needed.
Here are a couple pictures:
Tim, have you seen the Trails Less Traveled Fender Trimming writeup? Why not continue the trimming right around, then do the rear? It would give you a ton of room, I think TLT fit 35's.
I do not want to get in that deep
I am thinking about doing a body lift, but am torn between 1 and 2 inch
not sure what has to be modded for each body lift size,,,,
I may do a 2 inch, I really am not sure, would like to see a couple rigs in person
that one guy from Ct. I think has a 2 inch
and Lee, thank you for the feedback, 1 inch might be the easiest way to go, without doing futher mods, I do want it to be simple
how long did it take you to do?
coffey50
07-28-2015 10:55 AM
terminator
07-27-2015 07:13 PM
rushw
07-18-2015 01:46 PM
crashburnoveride
07-10-2015 06:39 AM
