Is this a good price for a timing belt change?
Old 12-18-2008, 09:11 PM
YodaPala's Avatar
I went to a Toyota/lexus specialist called import auto and gott a price quote to do the good ol' timing belt and water pump. They quoted me $650.00 plus tax. which incluses the following:
Timing belt
tensioner
waterpump
oil seals
coolant flush (red toyota stuff)
a/c belt
pwr st. belt
alternator belt
All necessary labor to complete job.
(all parts are oem toyota parts)
Is this good? Its a good shop that I heared good things about. (ase cert. tecs) KInda skeptical I'd like to have the dealer work on it (when I can afford it) hmmmmmmmm
Old 12-18-2008, 10:44 PM
rocket's Avatar
That's better then average. I've read and herd quotes much higher.
Old 12-19-2008, 04:43 AM
emptypockets's Avatar
I had the exact same service done to my 4Runner a few months back, with about 93k miles. My total was $676.40 with tax, so you're getting a pretty good price from them.
Old 12-19-2008, 04:49 AM
Dan.3's Avatar
I would say its a good deal.
Old 12-19-2008, 06:39 AM
hross14's Avatar
yep, not bad
dgz32's Avatar
Yep. Not bad at all. I was quoted $750, and that didn't include the tensioner and seals.
*edit* Apparently hross14 and I speak the same language, lol
Old 12-19-2008, 07:47 AM
cackalak han's Avatar
Make sure they're using OEM parts. I'd even buy the parts from trdparts4u and bring them in.
Old 12-19-2008, 08:55 AM
cosmophonic12's Avatar
if they're using toyota parts i say its a great deal.
Old 12-24-2008, 02:32 PM
Ron Helmuth's Avatar
A dealership would likely come up with a few more things to at least check out while the front of the motor is apart.
Mine has mentioned things like some bearings-I don't really know which ones, but my point is while it is all taken apart it is best to be comprehensive in checking all parts that could need servicing. A few more dollars now could save hundreds later if it all has to be taken apart again.
I would have your Yota dealership quote you also for the job so you can learn the specifics of what I am getting at...I am not a mechanic.
use that quote as ammunition to get the most complete job while it is apart.
I'm not suggesting anything is wrong with your shop's quote or price-merely that you be sure you are getting the most thorough job and all done at once.
voiddweller
19
05-02-2016 09:10 PM
fasterspider
10-06-2015 10:24 AM
layifioren
10
07-06-2015 02:26 PM
marcusSRG
06-27-2015 07:13 AM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: Is this a good price for a timing belt change?
