good n Cheap!!! paint stripper?
Whats a very good paint stripper for ultra high heat paint? Something I can pick up locally, and most importantly no more then $5-10.
I tired acetone and some paint thinner, it didnt even make a scratch
thanks
thanks
you could try citri-strip, its user friendly and available at most hdwr stores. its sort of a gel like substance so it will cling to verticle surfaces, it has its own scrubby pad to help remove the surface coating as it is dissolved away.
lee
lee
thanks
thanks
yeah I'm going to head out in a bit and look .. I was just hoping someone knew a name I could look for that worked, save me some time n money.
Leebee- thanks, I'll look for it
You simply can't use "good", "cheap", and "stripper" in the same sentance and not expect a few snide remarks and giggles.
I might be able to help you out if this didn't have anything to do with paint.
Ed
Ed
Ed
Ed
oooo! i like the sound of that! too bad im so far away.
lee
Originally Posted by jimabena74
jasco makes some gnarly strippers for all sort of stuff.....
Marhyde Aircraft Coating Remover
About $5/can at your local auto parts place
It'll take the paint off anything and your skin...don't breath it either. Took the powder coating off the Can-Back rails like it was butter and you usually have to scrape powder coating, but it was a crappy powder coating job.
I'll second that stuff-I once used it to strip the coating off of aluminum wheels before I painted them. But wear good gloves and cover your mouth and nose!
Ed
Ed
All jokes aside, I bought a paint stripper a couple weeks back for about $15, did a good job if you followed the instructions, I don't have the can anymore, wish I could help. Follow the instructions and you'll do ok kid....
As cool as the aircraft coating remover sounded .. the guy at home depot looked at me like I'm crazy and looked like he was about to call homeland security on me cause I was looking to strip an aircraft.
So I got some other paint stripper stuff ... it did the job pretty well, along with a scraper tool ... I think if I sanded it, I could get a smoother finish though.
In anycase thanks again for the help guys!
i vote for the mar-hyde, works good http://www.bondo-online.com/catalog_...sp?itemNbr=318
BeMiceElf
10-10-2015 09:40 PM
09-04-2015 09:27 AM
