Going from E-Locker Diff. to Open Diff.
Old Oct 10, 2006 | 04:23 AM
pinkfloyd73's Avatar
I have a 2000 prerunner with the e-locker and want to go with an open locker for a limited slip. Do I need the whole axle and diff. assembly or just the diff.?
Old Oct 10, 2006 | 04:33 AM
Localmotion's Avatar
too bad you have a taco or I would buy your e-locker.
you can sell your elocker and get a open diff and intall the Limited slip. or you can just swap thirds IIRC.
Old Oct 10, 2006 | 05:20 AM
bamachem's Avatar
i have one question... why?
and i have a question for you... why would that matter? an e-locker is an e-locker. they're all 8" toyota third members and are interchangable. the NON-TRD 2WD prerunners have a 8.4" third - basically the same as a tundra or sequoia. all TRD taco's have an 8" third with e-locker - either prerunner or 4WD - same as the 4runners.
Old Oct 10, 2006 | 05:23 AM
Bighead's Avatar
I'm with Andy on this one.
Old Oct 10, 2006 | 05:49 AM
neliconcept's Avatar
maybe he wants to drag race it? interesting question why?
really really interesting question
Old Oct 10, 2006 | 05:52 AM
mastacox's Avatar
Well, I know there are PLENTY of people that will be willing to buy that thing from you, you'll be able to get a pretty penny for it.
Old Oct 10, 2006 | 06:22 AM
AH64ID's Avatar
IME, limited slips work when you dont want them to (i.e. on ice), and dont work when you want them to (i.e. off-road)...
Old Oct 10, 2006 | 06:32 AM
mastacox's Avatar
This is just so true... I think that needs to go into the Yotatech quotes hall of fame
Old Oct 10, 2006 | 06:42 AM
bamachem's Avatar
if he's going to drag race it, then he'll be going in a straight line - the precise situation where an e-locker would be MORE beneficial than a limited slip rear.
if he's going to need more traction in a turn - like in auto-cross stuff - then he needs to sell the taco and get a subaru.
there is NO common situation that i can think of where a limited slip would be MORE beneficial than a e-locker, on-road or off...
Old Oct 10, 2006 | 06:49 AM
Albuquerque Jim's Avatar
This isn't a question of why or should I. The question was...
The simple answer is you need the whole axle to make the swap relatively easy. The complex answer is...if you modify the housing you can switch 3rd members.
I modified a non-e-locker housing to accept an e-locker, so I would assume you could do it the opposite way.
Old Oct 10, 2006 | 07:49 AM
BajaRunner's Avatar
Kinda off topic, but, did the Tundra's come with e-lockers? My dad has a limited slip in his Tundra and it sucks. We got stuck twice in Baja last year and wished we had a locker back there.
Old Oct 10, 2006 | 07:54 AM
bamachem's Avatar
no. the tundra, sequoia, and non-trd tacos have a 8.4" rear end. they are only available with a LSD.
Old Oct 10, 2006 | 09:31 AM
AH64ID's Avatar
Unfortunatley I spent WAAY to much money on them before I figured that out....
Old Oct 10, 2006 | 03:25 PM
Well, I have basically turned a prerunner into a more street-wise truck. I lowered the front and rear and was thinking about getting a diff. that would be more useful to me on city streets to take care of the slipping and traction problems that I am having now. So basically, I need something that will act right in sharp, fast turns. Just more streetable.
Old Oct 10, 2006 | 03:29 PM
I know that a prerunner was not intended to be a street truck but I only have 45,000 miles on the truck and I have used the locker one time. So, I'm basically turning my truck into a project.
Old Oct 10, 2006 | 03:34 PM
RunnerUp's Avatar
i have a killer deal for you, ill swap axles with you, i may even pay shipping if your lucky!!
seriously though... i will trade you
Old Oct 11, 2006 | 12:20 AM
AH64ID's Avatar
Your best bet would be to swap someone axles.. its will be the easiest and cleanest. Personally I would rather play with a little brake fluid that gear lube. As far a a limited slip they didnt come from the factory with one so you will have to add it. If you get one get a detroit trutac, its got helical gears and it torque biased.. dont get a clutch pack one all they are is a waste of money.
There are plenty of people here that would swap you... probally even buy you a LSD and swap you...
Old Oct 11, 2006 | 12:28 AM
Elton's Avatar
i have a e-locker and i never use it .... i wish there was a better writeup on how to use it anytime instead of 4Lo only
Old Oct 11, 2006 | 12:49 AM
AH64ID's Avatar
There are several ways to do this, the first has to do with the stock setup and is electrical.. not sure on the complete proceess but look HERE.. the second is to get a cable acuator for it from downey..
Old Oct 11, 2006 | 12:53 AM
Elton's Avatar
going way off topic......... i did it like this http://www.hboss.net/4runner/locker_safety.htm and it just blinks ... see the link button works for you
Badlander
Oct 10, 2015 08:05 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
dbollier123
Sep 29, 2015 05:23 PM
PNW94Runner
Sep 29, 2015 02:55 PM
