Gears???
Old 04-26-2005, 08:14 AM
hatebreed121's Avatar
Gears???
ive got a 92 PU 4wd (22re) i put on 31's and rims and i hear that i should put in better gears, what ratio should i put in, do i have to do front and back, how much would this cost, where could i have it done, could i do it myself, what company should i look for, or should i just leave it as is.
Old 04-26-2005, 09:22 AM
AxleIke's Avatar
Yes, you must to front and rear. You will have problems trying to use 4 wheel drive if you dont. Use your axle code to find the stock gear ratio. It's on the metal plate on your fire wall under the hood. Use this code (new tire size/old tire size)*stock gear ratio.
mskalmus
05-28-2017 07:51 AM
norcal98
08-10-2015 06:20 AM
wolfpackfan33
08-02-2015 03:36 PM
Shaun Crystal Gomban
07-30-2015 10:13 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
Quick Reply: Gears???
