Gear ratio question
Old 01-28-2004, 01:31 AM
Tacoma Dude's Avatar
Question Gear ratio question
I asked this in another thread but I didn't get an answer...
My truck's stock gear ratio is 3.91
Will I be able to take a 3rd member with an ARB locker geared at 3.93?
I know nothing about the gearing stuff and have no idea if that .02 will make a difference.
Thanks everyone!
Old 01-28-2004, 04:50 AM
JD
JD's Avatar
The difference in ratio is insignificant and will not cause a problem.
Old 01-28-2004, 05:23 AM
toy283's Avatar
According to your sig you're 2wd. Swap it in! The only possible issue would come about with 4wd, but the diffference is small enough that there wouldn't be any anyway.
Old 01-28-2004, 05:38 AM
Senior Member
jacksonpt's Avatar
If you're 2wd, the gear ratio doesn't matter - you can swap in a 3rd with whatever gears you want.
Old 01-28-2004, 12:37 PM
Cooooooool!
Old 01-28-2004, 12:38 PM
...another thing, is an ARB air locker installation something I could do? Or is it such a paint that I should get it professionally done?
Thanks!
Old 01-28-2004, 12:47 PM
toy283's Avatar
If you've never set gears, or don't have the tools to do it, have it professionally done. I've done a few ARB's, it isn't really any more difficult than setting the gears themselves, just adds a little more time.
Old 01-28-2004, 12:53 PM
Hmmm... do you know how much I should expect?
... and is $540 still a good deal?
Old 01-28-2004, 12:57 PM
OneTrickToy's Avatar
If you are talking about buying a third with the ARB locker already installed, then yes, you can do it yourself. Installing a new third is very easy!
If you are talking about installing the ARB locker into the third member, then have it professionally done.
Old 01-28-2004, 03:22 PM
toy283's Avatar
There's no way a truck came stock with 4.11's in front and 4.90's in the rear. FWIW, that isn't even a 9" gear ratio (4.88 is closest). There are quite a few mismatched stock vehicles. Usually, they are a point or two different with the higher (numerically lower) ratio in front.
Old 01-28-2004, 04:08 PM
toy283's Avatar
I can see that as a factory mismatch. A little large, but not excessive and certainly feasible.
Old 01-28-2004, 04:10 PM
Flygtenstein's Avatar
Wasn't 4.09 to 4.11 a common Bronco mismatch?
Not to completely hi jack or anything.
Old 01-28-2004, 04:16 PM
zedex's Avatar
My 67 bronco was 4.11 in back, 4.10 up front.
toy283's Avatar
Yup. 4.09 D30/44 and 4.11 9"
oldirtydirt
02-23-2020 09:30 AM
mskalmus
05-28-2017 07:51 AM
88sasturbotoy
08-11-2015 01:56 AM
coffey50
07-28-2015 10:55 AM
smiley52
07-11-2015 05:16 AM
Quick Reply: Gear ratio question
