Gear Ratio
Gear Ratio
Ok, I found this link! http://www.sonoransteel.com/Toyota_axle_codes.html
But its still kinda confusing. My model is #VZN185L-GKPZKA
Now it gives you two options..one with 4.10 & 4.30 w/265/70/16. So if my 4Runner comes with 265/70/16..I have 4.30?
There is an axle code on the door jamb vin sticker.at the bottom you should see A/TM. The first 4 Letters & numbers are your axle code. A03A for example.If you get that code you can get your stock axle ratio .What part of PA are from?
Shubey
Shubey
Ya, 4.10 it is....http://www.brian894x4.com/Gearratiosanddiffs.html
Shaun Crystal Gomban
07-30-2015 10:13 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
