Gear Lube
Old 11-19-2003, 05:30 PM
4x4Lamm's Avatar
Gear Lube
I read that if you go through some real deep water you should change your gear lube ASAP. Is this true? How bad can a little watter be in all that oil? Haven't done it, just wondering.
Old 11-19-2003, 05:45 PM
keisur's Avatar
if you extend you breathers you shouldn't have to worry about it. otherwise if water does get in you need to get it out quick. water is less viscous than the lube therefore more heat builds up and can or will damage your gears. I think that's it.
Old 11-19-2003, 06:11 PM
INsr5runner's Avatar
water heats different than the oil. If you get water in your diff, when they get hot, it will boil the water, and cause your diff to litterally "blow up." gear oil will come out the diff, and you will have fried your diff.
In the transmission, it gets nice and pink, and turns thick...looks a lot like Pepto Bismo
calderp
Engine Swaps
08-16-2016 05:15 PM
altydog
07-28-2015 10:20 AM
calderp
07-27-2015 09:58 AM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
Hamonacracker
07-17-2015 08:33 AM
Quick Reply: Gear Lube
