Gas door stuck closed!
Old 08-12-2011, 06:52 PM
madbomber08's Avatar
Was trying to do a good thing to my 4runner by extending the differential breather to the gas cap, but a really bad thing happened. We finished putting in the last o-ring for the rubber boot around the cap and finished screwing the door latch mechanism and it was getting fairly tight but the nut didn't look threaded on as much as when i unscrewed it to get the boot off. I looked at the release pin to see if it would even hook on the door latch and it did. So i closed the door, then pulled the release lever on the inside a couple more times and thought it didn't feel as "tight" as it did when i took it off. Then i shut the gas door another time and..... IT WOULDN'T OPEN AGAIN! The release lever absolutely had no tension besides the spring that pulls it back flush to the panel.
My only guess would be the black cord that pulls on the mechanism by the gas door must have came unhooked. I have no idea how to get the door open to fix it now. Someone has had to have had this happen to them before.... oh and the best part is the gas cap isn't even on!
Old 08-12-2011, 08:13 PM
streetlancer's Avatar
Big fat hammer time....
Old 08-18-2011, 07:10 AM
Hokkaido's Avatar
Drill a hole in the gas tank, run a garden hose to the back seat. Stick a funnel in and fuel as needed
Or perhaps a small/med well placed screwdriver levered against a thick rag would open the door with minimal damage, as mine did. You'll see how worthless the door thing is to begin with.
Old 08-19-2011, 10:09 PM
It was very easy to get at by removing the rear panel. I didn't even remove the panel all the way but as long as you can get it enough to get the gas door open your fine. Once you have the door open you can get the boot off around the gas cap. Case closed.
westonian18
05-01-2020 06:38 AM
okamikai
04-30-2018 10:19 PM
pyramid
07-30-2015 10:05 AM
britishdudes2dr
07-25-2015 06:47 AM
CanRunner
07-20-2015 01:29 PM
Quick Reply: Gas door stuck closed!
