Which fuse to pull on deckmod 2.7L?
Old 06-19-2003, 12:11 PM
ewarnerusa's Avatar
Question Which fuse to pull on deckmod 2.7L?
I am in the middle of a deckplate mod for a 2.7L 2001 Tacoma. It is going great, I can't wait to fire it up. I was planning on pulling the EFI fuse when I'm done, like I've read you should do. I've read that the computer will relearn on it's own if you give it some time (a tank or two of gas), but it moves along faster if you reset the computer by pulling the EFI fuse. Is this correct? And I'm not sure which fuse to pull, since the writeups i've read are for the 3.4L and it is a 15A fuse that you pull. The only EFI fuse I find is a 20A fuse. Please see attached picture with the EFI fuse circled in red. Is this the right one to pull? Thanks.
Old 06-19-2003, 12:16 PM
Tacoma Dude's Avatar
That's the same fuse I've been pulling for my ISR mod.
That's also the same fuse I pulled yesterday that cleared my check engine light.
I'm not sure what everyone else will tell you but I think you've got the right fuse.
Old 06-19-2003, 12:18 PM
ewarnerusa's Avatar
cool, thanks. What is an ISR mod?
Old 06-19-2003, 12:22 PM
Dr. Z's Intake Silencer/Reducer Removal
It's in the tech section.
There's no write-up for the Tacoma 3.4 as there are minor differences w/ the 4 Runner but if you do a search on it you'll find that <96 Runner> has a setup that will work fine in our rigs.
The idea is very simple and the mod is reversable in the event that you're not satisfied with it.
80Truck
07-24-2015 03:12 PM
v_man
07-23-2015 04:01 PM
yourrealdad
07-21-2015 11:13 AM
rushw
07-18-2015 01:46 PM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: Which fuse to pull on deckmod 2.7L?
