Fuse Panel under the hood
How to you remove it? I need to replace the little white power wire that runs from the battery to the fuse panel. I did a search but didn't find anything.
Thank you
Thank you
Why do you need to pull the whole fuse box out if you're just replacing the white wire...??
From your picutre I know what you are talking about... the white cable or wire is not present , it connects to the lower left corner stud and runs through the top left hole then to the battery-- I have two power wires connected at this point and did'nt have to remove the box at all...
Can you be more specific on what you are trying to do...???
I'm trying to remove the panel where all of the fuses are. I can see that there are 3 tabs that need to be uncliped, which I did. The front part of the panel comes out a little way, the back (closest to the fender) doesn't move at all. I'm trying to remove this so that I can replace the white wire. Right now I have sodered with another piece of wire and it looks like crap.
Does anyone have a FSM that they can look at and maybe post a pic on how to remove it, I'm sure that is pretty detailed.
Originally Posted by Noliwan
Why do you need to pull the whole fuse box out if you're just replacing the white wire...????
jasonty
41
12-23-2018 01:00 PM
FS[PacSouthWest]: 1988 4runner $1500
4x4-runner
08-03-2015 07:14 PM
rushw
07-18-2015 01:46 PM
