Fun with ball joints
Old 11-07-2015, 04:56 PM
Darryl01088's Avatar
Attachment 1032042001 taco 3.5 Trd supercharger, 5 speed with 130k on the clock. I decided to rebuild the front end. I replaced the inner and outer tie rods 3 years ago when I installed a lift kit. My left hand CV axle boot ripped sometime over the summer. I figured since I had to disassemble the lower BJ to replace the drive shaft I might as well replace the upper and lower ball joints along with the sway bar end link. The boots were ripped. I didn't feel any excess motion in the joints but I have seen the carnage when a ball joint fails so why not. Well that is where the fun began. I could not get the sway bar end link out. I heated it...tried penetrating oil you name it. After an hour of futile effort with the impact, I broke out the angle grinder. I cut the nuts off as close to the bracket as I could then used an air chisel to break off the remnants of the nut and punched out the link. That was the hardest part of the job. Everything else was pretty straightforward.
Got the Left side reassembled last week. I used plenty of anti seize on the threads when I installed the lift kit but rust sets up quickly here in the northeast.
My advice is to use a Liberal amount of anti seize whenever and wherever they can. Well enjoy the photos ...working the right hand side tomorrow...wish me luck.
Old 11-08-2015, 12:12 AM
wyoming9's Avatar
Red face
I guess your pictures failed to load!!
Just where in the great Brine belt are you ??
Old 11-09-2015, 06:24 AM
vasinvictor's Avatar
Sway bar? Those things are overrated
Old 11-09-2015, 12:19 PM
wyoming9's Avatar
Red face
I kinda like having mine installed .
I will admit it is a personal thing.
Old 11-11-2015, 08:59 AM
Pipsisiwah's Avatar
When one of my sway bar end links broke and I drove through some dips on the interstate, the truck flopped from side to side like a fish out of water. I had to slow to below 65 in several places when the truck felt kinda -well- fishy. That happened twice BTW. If you like a truck that feels out of control then fine. Until you lose control and injure/kill somebody in another vehicle.
aowRS
09-13-2017 08:22 AM
RammerX
08-29-2015 01:10 AM
bobjohnson2121
08-28-2015 04:02 AM
jake_v
08-27-2015 08:53 AM
CratesCruiser
08-23-2015 06:12 AM
Quick Reply: Fun with ball joints
