Full time power outlet MOD - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-22-2004, 05:50 PM   #1 (permalink)
fooddude's Avatar
Send a message via AIM to fooddude
i read the write up on the full time power outlet mod and saw people on do writeups on their 3rd gens. So what im asking here is, is it possible to do it on a second gen runner. If so could someone tell me if its the same or a little different.
__________________
95 SR5 4x4 4runner
Sony Xploid cd player(not sure which one)
Rockford fosgate 900 watt 2 channel amp, 2 600 watt kenwood 10 inch subs.
Some cheap cb from walmart
Surco safari rack with 2 KC Daylighters
15x8 tech 1 rock crawlers
Spintech exaust
external fuse box mod.
Airbox MOD. K@N Air Filter. ISR MOD
Downey HD's
fooddude is offline
Old 02-22-2004, 06:55 PM   #2 (permalink)
fooddude's Avatar
anyone
__________________
95 SR5 4x4 4runner
Spintech exaust
Downey HD's
fooddude is offline
Old 02-22-2004, 08:20 PM   #3 (permalink)
Tacoma Dude's Avatar
Send a message via AIM to Tacoma Dude
I don't really see how it could be any different?
Are you talking about the method that involves installing a new fixture? Or are you talking about the method that involves just a little rewiring?
__________________
Peter!
2002 Tacoma
1986 4Runner
Tacoma Dude is offline
Old 02-22-2004, 08:26 PM   #4 (permalink)
fooddude's Avatar
just where you rewire in the fuse box.
__________________
95 SR5 4x4 4runner
Spintech exaust
Downey HD's
fooddude is offline
Old 02-22-2004, 08:34 PM   #5 (permalink)
Ah..
I have no experience with anything other than my own truck but I don't see why it wouldn't work?
As for me? I'd rather add a device. Kind of like Bob's or Corey's write-up in the tech section.
Corey's write up - the one that involves the multi DC to one (like a power strip) - I prefer most. No drilling, quick and easy to do. Best of all, easily undone.
BUT I'm not answering your question so here's a BUMP for ya
__________________
Peter!
2002 Tacoma
1986 4Runner
Old 02-22-2004, 08:40 PM   #6 (permalink)
fooddude's Avatar
thanks anyways tacoma dude. I was thinking about doing the outlet mod corey has instead. I have found the same unit has him but it has 3 outlets instead of 2. I dont know what i will do with 3 though.
__________________
95 SR5 4x4 4runner
Spintech exaust
Downey HD's
fooddude is offline
Old 02-22-2004, 08:55 PM   #7 (permalink)
Actually, I have the same thing too
I haven't put it in though... no time and plans surrounding my truck are in the air.
__________________
Peter!
2002 Tacoma
1986 4Runner
Old 02-22-2004, 09:00 PM   #8 (permalink)
Phalanx's Avatar
Send a message via AIM to Phalanx
Here's a writeup on a 2nd gen.
I did mine a little different. I ran a (fused) wire driectly to the inverter from the battery. I transfered the on/off switch on the inverter to the wall switch. I also set it up in the storage compartment on the drivers side.
In the near future im going to run a 0 gauge wire from my battery to a breaker under the hood and then all the way to the back. This will cut down on all the fuses and clean up the wiring I have now. Somebody already mentioned this idea on the forum but I forgot who.
This is the only real pic I have of my setup
Look Closely
__________________
Rig Specs
'94 4Runner 3.0L V6 4x4, 32" BFG Mud T/A KM, 4" SAS, All-Pro Bumpers and Sliders, Rear Cruiser Coils, Bilstien 5150's all around, Warn M8000, K&N Filtercharger, 300w Power Inverter, Optima Yellow Top, Viair 450C, Cobra 75WXST CB w/ Firestik II, Flowmaster 40 Series, Viper Keyless Entry, Rear-Detroit Soft Locker, Front-Detroit EZ Locker
Trail Pics
Phalanx is offline
Old 02-22-2004, 10:38 PM   #9 (permalink)
Quote:
I did mine a little different. I ran a wire driectly to the inverter from the battery to the inverter. I transfered the on/off switch on the inverter to the wall switch. I also set it up in the storage compartment on the drivers side.
Look Closely
Phalanx,
If I read what you wrote correctly, you have a single wire directly to the inverter. If so, this is not safe especially if you have the wire spanning the entire length of your 4runner. Check out my write up for reference, esp Step 3.
http://www.4runners.org/articles/dist/
If by chance there is some electrical overload or some other anamoly, the *entire* length of that wire running to your inverter will heat up and may catch fire. Talk about a disaster!
The safest way to hook up your inverter is create a short (12" or less) wire from your battery's positive wire to the fuse. Then run a wire the rest of the way to your inverter. That way, if the wire catches, the fuse will "pop" and effectively eliminate the chance of the wire catching fire. If it does catch fire, it will only be the 12" short section.
This is my wiring diagram: http://www.4runners.org/images/dist/master_plan.jpg
Bob
Bob_98SR5 is offline
Old 02-22-2004, 10:46 PM   #10 (permalink)
Co-Founder/Administrator
Staff
Corey's Avatar
Quote:
Did you see my write-up for the 2nd gen?
It's in the Tech zone.
http://www.yotatech.com/~corey/tech/corey_12v/corey.htm
Full time power all the time.
It would do you good to do both it and also the aux. fuse box mod I did, also detailed in full in Tech.
http://www.yotatech.com/~corey/tech/..._box/corey.htm
Corey is offline
Old 02-22-2004, 11:20 PM   #11 (permalink)
Phalanx's Avatar
Bob,
There is a fuse on that wire before the firewall, little bit more than 2' but its there. I guess I was kinda vague. What do you think about the breaker idea?
__________________
Rig Specs
Trail Pics
Phalanx is offline
Old 02-22-2004, 11:24 PM   #12 (permalink)
Bob,
Phalanx,
With regards to breakers, I read a very compelling reason NOT to use a breaker in place of a fuse. However, I cannot remember what that compelling reason is at the moment (no old age jokes, please). But whatever it was at the time, i chose to heed that advice and go w/ the fuse.
Bob
Old 02-23-2004, 12:24 AM   #13 (permalink)
Quote:
Originally Posted by Bob_98SR5
...However, I cannot remember what that compelling reason is at the moment (no old age jokes, please)...
oh yeah, didn't you have a birthday recently?
__________________
Peter!
2002 Tacoma
1986 4Runner
Old 02-23-2004, 07:00 AM   #14 (permalink)
Staff
Corey's Avatar
After reading this again, I was not sure if you meant full time 12 or 110 v power, was sleepy last night
Here's mine for the 110 v one.
Very easy to do.
Corey is offline
Old 02-23-2004, 01:01 PM   #15 (permalink)
fooddude's Avatar
thanks corey for all the links. I was planning on doing the fuse box also pretty soon.
__________________
95 SR5 4x4 4runner
Spintech exaust
Downey HD's
fooddude is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
full time power outlet??? bsinwa General Electrical & Lighting Related Topics 19 07-13-2006 10:39 PM
Full Time Power Outlet Mod - 99 4Runner Bob_98SR5 Electrical 0 12-31-2005 08:12 PM
Full time power outlet in 90 pickup MorphiasX 95.5-2004 Tacomas & 96-2002 4Runners 0 02-12-2005 11:48 PM
NEW MOD - 12V Power outlet in console ManyMods 95.5-2004 Tacomas & 96-2002 4Runners 4 08-15-2003 07:32 PM
2009 InternetBrands, Inc.
