Fuel lines rusted. Can't get filter off.
Old 10-16-2009, 03:10 PM
Canadian Bacon's Avatar
I'm trying to get my 10 year old original fuel filter off my 4Runner but it is rusted bad. Soaked it with rust inhibitor for a couple of days, and I tried clamping on tight with vice grips but I'm still rounding corners. I do not have the proper flare wrenches but I doubt that would even work with how bad these fittings are. I would like to avoid putting in a new line.
Any ideas?
Thanks.
Old 10-16-2009, 03:55 PM
stir_fry_boy's Avatar
I would still try a flare wrench. But if you can't get it out, you are SOL. I know you can remove the metal pipe going into the filter (on the other end of the metal hose from the gas tank) with a special tool which is used for a quick high-pressure disconnect. It should be right before the filter (about 4-6 inches). As far as the other end, I think I saw it connected somewhere in the engine bay (long hose).
Old 10-16-2009, 04:10 PM
g_cali's Avatar
I used an impact on mine
smthwsn357
12-04-2023 02:08 AM
Sleaker
08-26-2020 06:03 AM
the1998sr5
15
07-14-2020 08:35 PM
Poppie51
07-23-2015 05:03 PM
Fundy Rider
07-16-2015 01:35 AM
Quick Reply: Fuel lines rusted. Can't get filter off.
