Fuel line fittings size 3.4L
Does anyone know the size (diameter and pitch) of the inverted flared fittings on the end of the fuel supply line to the fuel rail on a 3.4L '00 Runner. The fitting I'm talkig about is located forward of the brake booster and connects the fuel line to from the fuel rail to the hard line to the fuel pump / tank.
Another fitting size question - I believe the banjo bolts on the fuel rail are 10mm diameter but what is the pitch - 1.00 or 1.25?
Thanks for input.
Vic
Thanks for input.
Vic
I plan to install a fuel pressure regulator at this connection and do away with the stocker. I also plan to install a fuel pressure gauge on the fuel rail using a double length bajo bolt.
09-04-2015 09:27 AM
