Fuel injectors..... - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-01-2004, 01:54 PM   #1 (permalink)
weezy's Avatar
Send a message via AIM to weezy
Fuel injectors.....
Can anyone give me a quick idea of the procedure for replacing the fuel injectors on a 3.0? Pics would be great cause this girl is visual.
__________________
Mr. Yoda
Trucks aren't just 'boytoys'!
weezy is offline
Old 12-01-2004, 03:24 PM   #2 (permalink)
eric-the-red's Avatar
Quote:
pm me an email address and I"ll send you the relevant section from the factory manual, with exploded diagrams and procedure.
eric-the-red is offline
Old 12-01-2004, 06:30 PM   #3 (permalink)
leebee's Avatar
hey eric!
do you know the link for downloading the fsm? it was posted on here the other day and i cant find it for the life of me. thanks.
lee
__________________
93 sr5 v6 auto, 4x4
Photos http://s866.photobucket.com/albums/a...albumview=grid
there are quite some attractive ladies on here with Toys. (compliments of ironmike)
ifsc 3(.0)
http://tlca.org
www.of4wd.com
www.sontt.com
leebee is online now
Old 12-01-2004, 08:35 PM   #4 (permalink)
AgRunner06's Avatar
Send a message via AIM to AgRunner06
I did this this past weekend. I don't have time to write about it now because of school but I'll try to post it tomorrow night.
:bounce2:
__________________
"I'm your huckleberry." - Doc Holiday
- '93 4runner - Sold!
Current Ride - 2001 Chevrolet Silverado 1500 ext.cab, pewter, 5.3L, 3.42s, fully loaded, 68K miles.
FREE ROCKET!!!!
AgRunner06 is offline
Old 12-02-2004, 07:50 AM   #5 (permalink)
Is it easy to do (in general)?
__________________
2002 Sport Edition 4Runner
- Goodyear MTR 265/75/16
- ToyTec Coilovers
- OME 906/N86C
- Ashtray Mod!
89-4run is offline
Old 12-02-2004, 09:21 AM   #6 (permalink)
Quote:
Originally Posted by leebee
hey eric!
lee
Sorry, no, I didn't pay much attention to that as I downloaded mine about a year ago. But I just noticed this morning I still have the entire manual in a zip file. If you want it send me an email address. Note though it's a big file, just over 20 Mb.
Old 12-02-2004, 05:03 PM   #7 (permalink)
AgRunner06's Avatar
Ok I'll give my quick input on replacing injectors on the 3.0. For someone who has never done any motor work (like myself), it isn't the easiest job but it wasn't all that hard. I could do it much faster now the 2nd time around if need be. It took me 7 hours to do but I ran into some problems with my injectors so that was probably an extra couple hours. Just make sure you take pics of the vacuum lines and remember where they go. Also be prepared to fix any broken linest that you find. One hard vacuum line is the big one that goes to the reed valve. It was a biotch and wouldn't come off until we lifted the intake plenum and pulled. Also the coolant line that comes out the back side of the TB is a PITA to get off unless you have some pliers that are like needle-nose pliers but wider. I've never seen any pliers like that and don't have any so that too had to be disconnected once we started pulling the intake plenum off. Also you may want to replace that hose clamp on that coolant line with a screw type one for easier removal the next time around. You can pull the intake plenum without pulling the EGR valve but I recommend that you pull it out as I had HUGE chunks of carbon all over it and in the intake plenum that I had to blow out with the air hose.
Also be sure you have a new intake plenum gasket. I would also advise you do the PCV valve and grommet while the intake plenum is off. You should get an extra valve cover gasket just in case the grommet brakes into pieces and falls into the valve cover. The whole top of mine crack off when we tried to remove it. A few small pieces broke off but we were able to get them out without having to pull the valve cover.
When you put it back together, don't forget to attach the vacuum line that is right on the underside (and out of sight) of some other vacuum lines that run back to the TB and by the EGR modulator (you'll see what I mean when you get to it). Leaving this unattached will make it run like crap and sound like you have an exhaust leak coming from that side of the motor.
Make sure you keep some spare injector o-rings just in case you tear one. Also depending on who rebuilds the injectors, I had a problem with the spacer that goes between the injector and the fuel rail. It was too soft and wouldn't support the 9 lbs of torque on the fuel rail nuts. I had to replace them with my old spacers and luckily it worked. It's been suggested on this board to use corn oil (if I remember right) to put the injectors into the fuel rails. I just used a corn and manzola blend from my pantry without any problems.
When I did the initial start-up, it ran that crap for about 10 minutes until all the carbon was blown out of the intake and oil out of the injectors. After that it ran like a champ.
That's really all I can think of. Other than that, with a manual it is pretty straight forward. I used a Haynes manual without any problems.
If you have any other questions, just ask as this install is still very fresh in my mind. But right now I'm going to sleep because school has got me running on almost no rest due to finals.
:bounce2:
__________________
FREE ROCKET!!!!
Old 01-12-2006, 06:58 PM   #8 (permalink)
hosh's Avatar
The pliers that agrunner06 described are call "Duck Bills".
__________________
95' 4runner -- sold
82' 4x4 -- organ donor for the 93 - but for now summertime playtoy
93' 4x4 extended cab --- Mods; buffalo dents- Future mods; SAS, 33"s, dual cases, motor rebuild
85' MR2 -- It Liiiiivvvveeeeessss!!!! and is almost on the road
87' EX500 -- basket case frankenbike
"life, liberty and the pursuit of all those who threaten us"
hosh is offline
Old 01-13-2006, 05:00 AM   #9 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
It is all in here:
http://personal.utulsa.edu/~nathan-b...90injector.pdf
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Fuel not getting to the injectors DarkGuy13 Newbie Tech Section 2 03-20-2007 03:46 PM
fuel injectors blainelukens Maintenance & Repair Archives 1 04-17-2005 11:31 PM
Fuel injectors Carlos 95.5-2004 Tacomas & 96-2002 4Runners 1 12-11-2004 03:31 PM
Fuel injectors Nate 95.5-2004 Tacomas & 96-2002 4Runners 5 07-22-2003 08:44 AM
Aftermarket Fuel Injectors/Fuel Rails Bumpin' Yota 95.5-2004 Tacomas & 96-2002 4Runners 1 03-17-2003 08:05 PM
2009 InternetBrands, Inc.
