Fuel injectors - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-21-2003, 04:27 PM   #1 (permalink)
Fuel injectors
Has anyone replaced fuel injectors? I have a 91 SR5 auto and it wont idle well ,I think i need to check my in jectors. How tuff is it to do? It has 200,000 on it. Do the injectors typically need replacing?
Nate is offline
Old 07-21-2003, 09:00 PM   #2 (permalink)
AgRunner06's Avatar
Send a message via AIM to AgRunner06
Post
I'm also interested. I'd rather do it myself if it isn't too hard to do.
__________________
"I'm your huckleberry." - Doc Holiday
- '93 4runner - Sold!
Current Ride - 2001 Chevrolet Silverado 1500 ext.cab, pewter, 5.3L, 3.42s, fully loaded, 68K miles.
FREE ROCKET!!!!
AgRunner06 is offline
Old 07-21-2003, 09:03 PM   #3 (permalink)
wimpywade94's Avatar
basically all you have to do is pull the vacume hoses, after you do that you unbolt the intake manifold and the fuel pressure reg,and mabey 1 or 2 things more on the auto, you then relive the fuel pressure using the fuel pressure relief bolt, then you just unplug the injectors and pull out the fuel rail, drop in the new ones wtih new seals and away you go. its pretty easy, just dont lose your bolts and take your time. and dont drop the injectors, that kinda sux.....
later
wade
__________________
86 runner, rebuilt motor, egr block off, headman header, 3"bl, 33x12.5 m/t's. Lots of work wanted to do. limited skills, funds, time and drive.
If you dont know where your going, anyplace will do.....
wimpywade94 is offline
Old 07-21-2003, 09:13 PM   #4 (permalink)
AgRunner06's Avatar
Post
Quote:
Originally posted by wimpywade94
...you then relive the fuel pressure using the fuel pressure relief bolt...
Where's this fuel pressure relief bolt? I've done relieved the fuel pressure before by disconnecting the fuel pump by unplugging the connector by the passenger feet and then starting the truck.
What did you do to keep from getting the vacuum hoses mixed up?
How much time would you say is involved in a project like this?
Is it really that easy to do? Maybe you just make it sound easy. I dunno.
Thanks
__________________
FREE ROCKET!!!!
Old 07-22-2003, 06:53 AM   #5 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
Might want to check all the other stuff before assuming it is the injectors causing your truck to idle poorly. Change all the tuneup stuff (air, fuel, plugs, wires, pcv, etc....) and clean the throttle body first (usually lots of carbon buildup in there). Replacing all the injectors is a reasonable job and can be big $$$$ so do the cheap stuff first to make sure that is the problem.
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Old 07-22-2003, 08:44 AM   #6 (permalink)
First do a compression check. If it in spec, great. If not then perform a cylinder leak down test to find where the compression is leaking from. That could be your idle problem.
Once you verify the compression is good, get a Motor Vac carbon depletion service done. It will clean the injectors, intake valves, and combustion chamber all right on the truck.
Rarely do the injectors need to be replaced. Cleaning them ususally solves most problems with them, and much cheaper. You are likely going to pay about $150 for each injector at the dealer.
Gadget
www.GadgetOnline.com
Gadget is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Fuel not getting to the injectors DarkGuy13 Newbie Tech Section 2 03-20-2007 03:46 PM
Fuel injectors..... weezy 95.5-2004 Tacomas & 96-2002 4Runners 8 01-13-2006 05:00 AM
fuel injectors blainelukens Maintenance & Repair Archives 1 04-17-2005 11:31 PM
Fuel injectors Carlos 95.5-2004 Tacomas & 96-2002 4Runners 1 12-11-2004 03:31 PM
Aftermarket Fuel Injectors/Fuel Rails Bumpin' Yota 95.5-2004 Tacomas & 96-2002 4Runners 1 03-17-2003 08:05 PM
2009 InternetBrands, Inc.
