Fuel injector HELP
Fuel injector HELP
I have just replaced injector number 4 my problem is that I have tried to set the fuel rail twice and each time I am leaking fuel am I not setting the rail right is there a trick to setting the fuel rail All help would be greatly appreciated As it is a lot of work getting to the fuel rail each time
Peter
Peter
Where is the fuel leaking from? I imagine you're probably pinching one of the o-rings... Or forgot to install one of them....
edit*** Message DeathCougar and Vital22re hundreds of times about this. Maybe they have a few tips on how to take off the rail more quickly, since they have done it so many times.
Hey
So I took all the advice given replaced all o rings used the lube and made sure I din not over torque the fuel rail bolts and YES no leaks THANKS TO ALL WHO REPLIED
Peter
Peter
Blamalam
03-12-2022 07:34 AM
Tacoma1313
08-17-2015 05:44 PM
pyramid
07-30-2015 10:05 AM
HookahRoo
07-20-2015 07:06 PM
