| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Fuel Injection Problems
__________________
courtney cooper |
#2 (permalink) | |
Quote:
If you're looking for better performance, try the deckplate mod and larger exhaust. You will notice a very marginal increase in performance. You won't gain much from the injectors, especially if they have been cleaned. If you are looking for a big bump in power, install a supercharger. Then you can add larger injectors and a few other things that will really give the beast some kick.
__________________
Alan 1996 Supercharged 4Runner Limited Hi Altitude 4Lo A 4WD club for Colorado and surrounding states |
#3 (permalink) |
For starters, you may want to first run a can of BG 44K through it. After you get done with that, you may want to change the fuel filter since the BG 44K may put a lot of deposits in it. Also wait to change your oil after doing the first two. I noticed my oil got dirty afterwards, especially on my Camry.
I found out about the BG 44k here. I am convinced it is good stuff. It really helped my 84 Camry run better. At the very least, change your fuel filter. When I changed the one in my Tacoma, it was really dirty. Also, I forgot to add, a throttle body cleaning may help too. You should be able to do all this yourself if you have the tools and patience.
__________________
Nic 1997 Tacoma 4X4 Xtra Cab 2.7L 5 speed Last edited by Nic; 05-09-2004 at 10:34 AM. |
#4 (permalink) | |
Quote:
Buy new fuel filter, plugs, and two cans of Seafoam Motor Treatment. Change the fuel filter. Read the directions on the Seafoam can. You want to run it through the fuel system, directly into a vaccum line. Seafoam will clean your injectors and remove carbon build-up. Change plugs. Motor should run much smoother and powerful, like new.
__________________
2000 UZJ100 Land Cruiser 2" OME and 33" Geolander AT's Blue Ribbon Coalition Toyota Land Cruiser Association |
#5 (permalink) | |
Quote:
How does the seafoam clean the injectors if you run it all through the vacum lines? That may clean the valves but how does it do the injectors?
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#6 (permalink) | |
Quote:
You are right. I was in a hurry and I did not explain myself completely. Run a can (16 oz.) with a full tank of gas to help clean the injectors. Run it through a direct manifold vaccum line (p.v.c. valve or brake booster) to clean carbon build up. Results = smoother idle, more pick-up, etc. This stuff really works great and I recommend it all the time. www.seafoamsales.com And no, I don't work for them
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| wires/fuel injection | hogie9ll | 86-95 Trucks & 4Runners | 6 | 05-22-2007 03:47 PM |
| fuel injection coversion | toyotapowerjustwheel | Offroad Tech | 8 | 03-04-2007 05:46 PM |
| fuel injection | 87solidlockedup | The Classifieds GraveYard | 1 | 11-27-2006 04:44 PM |
| Sequential Fuel Injection | Skydigger | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 12-10-2002 05:23 PM |
