Fuel filter question, need answer asap
Old 06-30-2004, 02:06 PM
AznSky's Avatar
So I got the old one off, and trying to put the new one back in. One side says OUT, and the other says IN. I'm guessing the "IN" side goes on the side coming from the fuel tank???
Old 06-30-2004, 02:22 PM
eric-the-red's Avatar
Sounds like a good guess, that's how I put mine in.
Old 06-30-2004, 02:31 PM
Flamedx4's Avatar
yep. In from tank, Out to engine.
Old 06-30-2004, 02:37 PM
AznSky's Avatar
ok well I tried starting the engine, and fuel started spraying out from the filter, I don't thought I had a straight connection butI guess I was wrong, how do you get a straight connectino?
Old 06-30-2004, 03:13 PM
AznSky's Avatar
Allright I must be retarded. Because I can't get the new filter to stop leaking on the "out" side. So finally I gave up and installed the old on, and that one fits fine!! Whaddya know????
Grrrrr......I'm gonna tackle this again next week. Any ideas?
Old 06-30-2004, 03:15 PM
OneTrickToy's Avatar
Well, it doesn't sound like you crossthreaded anything, because the old filter fits fine. Either you have the wrong filter(wrong size threads on the outlet), or you just didn't have the outlet line tightened down enough.
Old 06-30-2004, 03:17 PM
platform389's Avatar
I don't see any mention at all about the thin steel washers that go on BOTH sides of the union bolts. You did replace all those (4) on both ends of the filter right? A complete new set should have been in the box with the new filter.
Old 06-30-2004, 03:22 PM
rimpainter.com's Avatar
Hey Rob-
My 96 does not have any washers. You probably need to torque it down a little more. Did you try that? How do the threads look?
Old 06-30-2004, 03:31 PM
AznSky's Avatar
yea I didn't get any washers either. I'm pretty sure I didn't cross-thread anything cuz I could hand thread it a good amount, well see the "IN" part was hard to hand tighten from the beginning, and the "OUT" part was really easy to thread up to a certain point.
I thought I torqued it down enough, I didn't want to break anything either so I didn't use complete uber force lol. Threads looked fine, and I checked the PO and it's the same thing. Grr.............
Old 06-30-2004, 03:33 PM
ChickenLover's Avatar
A little teflon tape on the threads might help.
Old 06-30-2004, 03:35 PM
Put some more muscle into it you wimp.
Old 06-30-2004, 03:44 PM
AznSky's Avatar
yea I don't think teflon tape would have stopped the amount I had leaking. But I will try that next time.
Christian I tried calling you in the middle of it lol, but you didn't answer your phone.
Old 06-30-2004, 04:04 PM
You did? I don't have anything on my call history.
Remember, tech advice is $1.25/min
Old 06-30-2004, 04:08 PM
steelhead's Avatar
When you install the new filter you will be surprized as to the amount of torque you need to apply. When I changed mine it sprayed too, but I just kept on tightening down on it and everything worked out fine.
Old 06-30-2004, 04:45 PM
Guest
4RUNR's Avatar
I'm curious, is the filter you are putting in different from the one coming out?
Old 06-30-2004, 05:41 PM
AznSky's Avatar
I'm replaced the old fuel filter with a new one. It isn't like a paper type filter, it's the whole part.
Haha funny Christian, fine, I'm just gonna have to charge you for that CO4RJ DVD. So 25/1.25 = 20 min. of tech time. AWESOME!!!
Old 06-30-2004, 07:52 PM
Guest
4RUNR's Avatar
Doesn't the replacement look exactly the same as OEM? I was confused why you didn't know which was it was going in.
Old 06-30-2004, 10:15 PM
humanoid's Avatar
AZNSKY, I had the same problem you did on my 3.4. The "out" fitting would seat right on the filter so I put back the old one and it fit. The next day, I struggled with it again and same problem, but I finally got it to fit. You just gotta make sure the fitting goes in straight into the filter or you will have tons of fun trying to put the fitting on. I read on another thread that had Gadget saying that putting teflon tape on the threads was a bad idea. If the factory didn't have it on in the first place then I don't see why you would need to put it on now.
Old 06-30-2004, 10:59 PM
superjoe83's Avatar
this probably isn't going to add much to this thread, but when i put a new fuel filter on my 2.7, the old one and new one had those little crush washers
Old 07-03-2004, 01:03 AM
Bob_98SR5's Avatar
guys,
i did a write up that explains the procedure: http://www.4runners.org/articles/fuelfilter
bob
smthwsn357
12-04-2023 02:08 AM
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
Alex Bessinger
08-31-2015 09:17 AM
Fundy Rider
07-16-2015 01:35 AM
Quick Reply: Fuel filter question, need answer asap
