fuel filter ?
Old 07-10-2004, 03:43 PM
jackamot's Avatar
fuel filter ?
hey people
i ve been looking into changing the fuel filter on my 87 runner the problem is that the replacement part is about 1/4 the size of what I have . is it possible that I have the original factory filter ? or am i looking in the wrong spot . .sorry i don't have pix . my engine is a 22re if that helps 5 speed . if i go with what is offered as a replacement is okay to fab together a homemade mount .. ?
Old 07-12-2004, 10:07 PM
jackamot's Avatar
anyone have an answer?
Old 07-12-2004, 10:09 PM
Tacoma Dude's Avatar
I wish I could help you there... have you talked to any of the service guys at the dealership? Maybe they could help you out some.
Old 07-13-2004, 05:59 AM
Mad Chemist's Avatar
Jackamot,
1) Have them double check the part number, the larger the filter, the more surface area = better filtration.
2) It should be mounted on/near the frame frame rail between the gas tank and the engine, at least on most vehicles. You should be able to trace the line all the way back to the gas tank.
Hope this helps!
Old 07-13-2004, 06:07 AM
TDiddy's Avatar
I thought the fuel filter on the 22re was in the engine bay?
Old 07-13-2004, 09:47 AM
deathrunner's Avatar
Allright, I think I've got this one. I have an 89 22re 5spd, so shoul dbe the same. The fuel filter is on the side of the engine block. Left side when standing in front of truck. It is just above the starter, underneath the intake manifold. It is a black cylinder. I have a replacement which is the same size, I would not recommend replacing it with anything different.
My best suggestion to getting at it would be this:
Get your front on jack stands, or at least get your left tire off the ground.
Remove the left tire.
Inside your fender well there is an access panel that you can remove. just above the upper control arm mount. Remove that panel.
This should give you a clear shot of the filter, but it will still be a squeeze.
Good luck
Old 07-13-2004, 01:22 PM
Fahrenheit 451's Avatar
Sounds like they gave you a filter for a carbed model instead of fuel injected.
The EFI fuel filter is quite big and should be something like a $20 part if memory serves.
Sounds like a trip back to the store is in order.
Old 07-20-2004, 09:45 PM
jackamot's Avatar
just got back in town thanx for the replys i will investigate tommorrow .. i knew the answer would arrive eventually ...any thoughts before i tackle the valve cover gasket .thanx again
smthwsn357
12-04-2023 02:08 AM
Eggslinger
06-08-2019 03:32 PM
pyramid
07-30-2015 10:05 AM
ddg71
07-24-2015 01:24 PM
Fundy Rider
07-16-2015 01:35 AM
Quick Reply: fuel filter ?
