YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 03-11-2004, 08:15 AM   #1 (permalink)
Sbrut95's Avatar
Fuel Damper??
I went to the dealership yesterday to find out what the heck was wrong with my car and they said I need a new Fuel Damper... Does anybody know exactly what this does?
__________________
1995 White 4Runner 4x4, 3.slow and 162k miles!
4" lift on 33" Trxus MT's. and some more junk...
Sbrut95 is offline
Sponsored Links
To remove this ad, register today!
Old 03-11-2004, 09:11 AM   #2 (permalink)
85runner's Avatar
It eliminates fuel pump pulsation before the fuel gets to the injectors. Unfortunatly, this is usually an expensive part. Try telling them you are in the Toyota Land Cruiser Association (TLCA). They might give you a benefit. This is something you can install yourself to save the hour of labor they'll charge.
__________________
Korrupt Krawlers
CrawlinAZ.com - Arizona Runs
85runner is offline
Old 03-11-2004, 11:09 AM   #3 (permalink)
Sbrut95's Avatar
Quote:
I was thinking of installing it myself, but I cant find anything on it my Haynes manual. Any suggestions?
__________________
Sbrut95 is offline
Old 03-11-2004, 01:39 PM   #4 (permalink)
Unhappy99's Avatar
This is also referred to as a fuel accumulator, and, ICBW, I don't think you have one. Call a different dealer and ask for a fuel damper or accumulator.
If case you do have one, they look like another fuel filter, except usually the innie and outie lines are on the same end. They have one fuel line in and one out, no electrical connection, and are located somewhere between the tank output and the fuel rail. Can be on either side of the filter. Most of them I've seen have been mounted on the inside of a frame rail before the filter.
HTH.
__________________
03 Dodge Ram 2500 CTD...its amazing
Ex: 1999 4Runner JT3HN86R1X0199261...Now somebody elses Karl Malone Toyota 'Certified' POS
Legendary Toyota quality is exactly that: A thing of legend.
Defective fuel gauge - 'Certified'
Defective brake rotors - 'Certified'
Defective axle seals - 'Certified'
Defective heater diverter - 'Certified'
etc. etc. etc.
Unhappy99 is offline
Old 03-11-2004, 02:26 PM   #5 (permalink)
85runner's Avatar
On my 85 its on the fuel rail.
__________________
Korrupt Krawlers
85runner is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Pulsation Damper or Pressure Damper vegascoug 86-95 Trucks & 4Runners 19 06-09-2006 11:12 PM
OME Steering Damper... flobadon 95.5-2004 Tacomas & 96-2002 4Runners 21 03-05-2004 08:51 AM
Fuel Damper problem? TDiddy 95.5-2004 Tacomas & 96-2002 4Runners 3 12-10-2003 12:13 PM
2003 4runner fuel pulsation damper RECALL impulsebrklyn 95.5-2004 Tacomas & 96-2002 4Runners 4 05-26-2003 09:34 AM
How to remove vibration damper? DH6twinotter Maintenance & Repair Archives 1 04-22-2003 11:30 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
