frozen rear window
Old 01-05-2005, 01:58 AM
smiljko's Avatar
frozen rear window
I am having problems with frozen rear window every cold morning.I am afraid to force it because my mechanic warned me that the motor would skip and then it would be realy expensive to repair it.Does anybody knows a way to prevent freezing because it is realy hard to put a lot of stuff in the trunk through a front door .The window realeses after truck is warm but often I dont have too much time in the mornings .
Thanks!
Btw. here are the first pics of my rig
https://www.yotatech.com/attachment....achmentid=4656
https://www.yotatech.com/attachment....achmentid=4655
https://www.yotatech.com/attachment....achmentid=4659
Old 01-05-2005, 03:33 AM
dgb9902's Avatar
Spray application of liquid fire type product or aerosol alcohol type window defroster along the bottom weather strip is usually enough to free mine up. Good Luck
Old 01-05-2005, 10:15 AM
smiljko's Avatar
I tried that -it didn't work -actualy the spray has frozen also-i'll try another brand.
Old 01-05-2005, 10:40 AM
Guest
4RUNR's Avatar
Dampen a rag in motor oil, then wipe all the seals and points of contact. The idea is to have something with water displacement properties that does not freeze and will stay on there.
Old 01-05-2005, 11:03 AM
smiljko's Avatar
Good idea I'll try that.
Thanks
06-01-2021 01:51 PM
jasonty
41
12-23-2018 01:00 PM
sabine
07-18-2015 03:59 PM
icentropy
07-14-2015 10:23 AM
coryc85
07-06-2015 04:07 AM
Quick Reply: frozen rear window
