Front Lower Control Arm bushings
Senior Member
Has anyone with a 3rd Gen had to replace the front lower control arm bushings? Mine squeak like crazy, they squeak all the time! Its driving me koo koo. :cry:
havn't replaced it yet, but I traced a sqeak to it recently and put some wd40 on it which helped so far. (btw the dealer quoted my 17$ per bushing!)
Senior Member
Yeah I placed some WD40 on them, but it doesn't help. I just wonder how hard it will be to replace these. I looks like a PITA to me...I'll check steve's site to see if he has any info... $17 per bushing isn't that bad then. Oh it squeaks even when I get out of it. It'll squeak the whole time while I'm driving down the road, it be drivin' me nuts..
Senior Member
Well I took it to the stealership this morning and they say they whole lower control arms up front needs to be replaced. Uhhhh....$700.00. I doubt its the control arm though. I still believe it is the bushing and not the control arm. Looks like I'll be buying some bushings and trying to replace this sucker myself. Has anyone ever removed the whole lower arm?
More than likely the reason they want to repace the enire arm is the bushings, like all the rest on the vehicle are probably pressed in.
I'll look in my 99 book, I'll be right back.
Originally Posted by data
You think I'll have to remove the whole arm as stated? Wonder how tough of a job this will be.
Senior Member
Ok here's the deal. I believe I'm gonna have to replace both sides, but I found a junkyard here locally that has a couple of 3rd Gen runners. They said they'd give me both left and right control arms for 100 bucks. I got quoted by the dealership yesterday for bushings and they ran about $54 each. So I believe I could save myself some trouble and just replace the whole arm. Good deal?
Senior Member
Yeah to me it seems like the logical thing to do. How hard is the arm to replace. I believe it is just a matter of taking out the bolt that has the adjusters on it for alignment, taking the lower shock mount off, and then popping the lower balljoint....
How long did it take you per side?
