Front End Traction....Lockers vs stock - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-10-2003, 02:35 PM   #1 (permalink)
Bumpin' Yota's Avatar
Send a message via AIM to Bumpin' Yota
Ok, I thought I had the ADD system from toyota on my 2nd gen yota. But today going up some hills near the beach (lots of sand) in 4wd Low, I noticed that my tires still spin independant of one another. Is this normal and will lockers make the front 2 tires lock as a unit?
Another question, on the stock 4wd yota's, the front 2 axles and cv's rotate with the tires. Will lockers (if unlocked) allow the axles and cv's to not rotate, there by reducing wear when you are on road?
Thanks guys,
steve
__________________
3vze, 4x4, sr5, 90, auto, LSD
2x dB Drag World Finalist
2003 Nopi Nat. Street B champ
2004 SBN Street C champ
2004 SBN Advncd NW Champ
2004 Former WR Holder in NW.
SPL: 159.8db @ 42hz
In loving memory of Jamie Riggs 5/15/85 - 10/8/04
Bumpin' Yota is offline
Old 03-10-2003, 03:04 PM   #2 (permalink)
Re: Front End Traction....Lockers vs stock
Thanks guys,
steve
yes, lockers make the front 2 tires lock as one unit. ADD simply referes to the hubs (or lack of hubs I guess, since it uses flanges or whatever) ...ADD just means they lock automatically when you shift into 4wd, manual are where you gotta get out and lock them in. ADD doesn't do anything to the differential.
I don't believe lockers do anything in terms of stopping the axle and cv rotation, when a locker is unlocked it operates exactly the same as an open diff (correct me if I'm wrong here)...you can do a manual hub swap if you want to lower wear on ure shafts/cvs.
__________________
New York City, NYC, pretty mean when it wants to be, black leather, knee hole pants, can't play no highschool dance, fuzz tone, hear 'em go, hear 'em on the radio - R A M O N E S, Ramones
OLD: '90 4Runner SR5 auto v6 150k
NEW: '85 long bed xtra cab 5spd 22R 200k
NEW NEW: '89 Ford Taurus SHO, 137k Miles, 650 miles after I got it : water pump takes a shizzle, now I'm knee deep in a front maintainence from hell. Even broken it's faster than the 4Runner
Los Gatos? is offline
Old 03-10-2003, 10:24 PM   #3 (permalink)
upndair's Avatar
Re: Re: Front End Traction....Lockers vs stock
Actually, the ADD is for Automatic Differential Disconnect and doesn't have anything to do with the hubs. In the 2nd gen 4Runner, the there's no real hubs to speak of. There is a vacuum activate system that lets the differential run free when 4wd is not engaged. I believe that this is to reduce the wear and tear, not to mention the drag of having the front drive train engaged.
A open differential allows the tires to spin at different speeds to assist in turning. The locker forces both wheels to turn at the same speed and forces the power to both wheels rather than just the wheel that's turning the fastest.
__________________
Gibby
1994 4Runnner
6" lift: Leaf spring conversion rear, SAS front. 1180 Ramp score.
DANA 60s with ARB lockers
39x13.50 IROKs
SBC 350, NP203 - NP205
Allpro bumpers and rock sliders.
www.faithwheelers.com
upndair is offline
Old 03-11-2003, 07:37 AM   #4 (permalink)
Ok cool, I noticed though that when i was in 4WD LO that all the tires still spun independant of one another....is that normal?
I had thought when my toy was dropped into the lowest 4wd gear that it would lock everything together.....
__________________
SPL: 159.8db @ 42hz
Old 03-11-2003, 04:20 PM   #5 (permalink)
Send a message via AIM to Salue
Correct me if I'm wrong, but I think you have ADD confused with being locked(with lockers). ADD is just what Gibby states and it just means that if you have it, your hubs or lack thereof are always in the 'lock' position(meaning you never have to go out to the wheel and turn a knob to set it to 'lock', instead you just shift into 4Hi or 4Lo and you're in 4WD). If you replaced the ADD flanges with manual hubs, then your outer axle shafts and cv joints/boots will not turn when they are in the 'free' position. So, when you are in 4 Lo, the tires will spin independently since you do not have a locker in the differential. Hope that makes sense.
Salue
__________________
'99 4runner SC
'97 Land Cruiser
'87 turbo 4runner...Sold
'91 4runner...Sold
'94 4runner...Sold
Salue is offline
Old 03-11-2003, 04:35 PM   #6 (permalink)
Flygtenstein's Avatar
ADD is a vaccuum operated system that slides collar to connect the short side axle with the differential. It has absolutely nothing to do with the hubs. Putting on manual hubs has no influence on the ADD system at all. Gibby said all of this.
When I lock my RD90, both my front tires spin at the same speed if one is in the air while the other is on pavement.
Open diffs allow differentiation side to side resulting in the tire with the least traction getting the power.
Flygtenstein is offline
Old 03-11-2003, 04:35 PM   #7 (permalink)
upndair's Avatar
Quote:
Salue
You are mostly correct. Even if you put the manual hubs on, you would still have an ADD system. If you look to the driver's side of the diff, you'll see a box with a couple vaccum hoses coming out. This is the ADD system that disengages the front diff when it's not being used. The ONLY real problem with this is that there is a weak spot in the long axle shaft where the ADD fork is. These axles frequently break at this weak point, especially if you add an LSD or locker. When I was running IFS, I found the parts from an older truck that didn't have the ADD and put that on instead. That's when I found that my long axle was broken and I was only getting anything out of the front wheels because I had a limited slip diff to give some power to the intact driveline.
__________________
Gibby
1994 4Runnner
39x13.50 IROKs
upndair is offline
Old 03-11-2003, 05:12 PM   #8 (permalink)
Ok, I got that the ADD = automatic differential disconnect and has nothing to do with the hubs. Im a complete newbie to the drivelines and suspensions and stuff...sorry guys. :cry:
So basically I have an open differential up front even when in 4LO?
__________________
SPL: 159.8db @ 42hz
Old 03-11-2003, 05:55 PM   #9 (permalink)
CTB
CTB's Avatar
Yes, you have an open differential up front no matter what you are in - 4Hi, 4Lo, etc.
__________________
1995 4Runner V6 4x4
CTB is offline
Old 03-11-2003, 08:12 PM   #10 (permalink)
BajaTaco's Avatar
Just for fun... I'll add to the confusion
1. your axles and CV boots will spin when the truck is rolling, regardless of whether or not the truck is in 4wd, or if you have a front locker or not.
2. Without adding a locker, your front diff is OPEN whether in 2wd or 4wd. This means the wheel with no traction will get all of the power whenever you lift a tire, or get into loose or slippery stuff.
3. Adding a full time locker will mean that whenever you engage 4wd, the front differential will become locked, giving equal traction to both front wheels, whether you like it or not.
4. Adding a selectable locker will mean that whenever you engage 4wd, the front differential can either be open, or locked depending on your preference.
__________________
Chris Marzonie
BAJATACO.COM
Toyota light expedition vehicle
Adventure reports
Lots of Photos
OVERLAND JOURNAL
North America's first vehicle-dependent expedition magazine
BajaTaco is offline
Old 03-11-2003, 09:05 PM   #11 (permalink)
ATC
ATC's Avatar
I have to ask a question now.
I also have the ADD on my '95 4Runner. If I added manual hubs would I have to get out & lock them if I wanted to switch into either of my 4wd settings just to drive around?
__________________
'99 Tacoma Xtracab SR5 4x4 TRD which features Borbet CW1 wheels, Cooper Discovery STT 31-10.5-15's. An ARB front bumper, WARN M8000 winch, a pr of PIAA 80's & a pr of PIAA 40's. OME 881 springs w/ firm valve shocks. In the bed is a custom Hi-Lift holder/light bar also w/ a pr of PIAA 40's. Inside is a Kenwood KDC-5019 head unit, Kenwood KTC-SR901 Sirius receiver, Boston Acoustic speakers & a Kenwood KAC-716 amp pushing an 8" JL Audio Sub mounted in the storage compartment.
ATC is offline
Old 03-11-2003, 09:16 PM   #12 (permalink)
upndair's Avatar
No. you could use your 4wd setting, but your front wheels would be useless until you lock in the hubs :o)
BTW, you shouldn't just drive around in 4wd, you should ONLY engage 4wd when you are in loose traction situations. Your front and rear wheels will turn at slightly different speeds which is OK on wet, or slippery surfaces but is really tough on the drive train on dry pavement.
__________________
Gibby
1994 4Runnner
39x13.50 IROKs
upndair is offline
Old 03-11-2003, 09:32 PM   #13 (permalink)
ATC
ATC's Avatar
No I don't just drive around in 4wd all the time. Let me be more specific. When I am in 4wd it is in snow, mud, creeks, or other driving conditions where 2wd won't cut it.
Now back to my original question. Do you mean that the ADD would be useless if I installed manual hubs?
What I want to know is if I am driving down the road for example & I hit a traffic jam & want to turn around in the median. Right now I can just shift into 4wd w/ the ADD & go. If I have the manual hubs can I still do this or do I have to get out & engage them as well?
__________________
ATC is offline
Old 03-11-2003, 10:38 PM   #14 (permalink)
upndair's Avatar
I think you're missing the point. The ADD has nothing to do with your hubs. It has to do with letting your front differential run free when NOT in 4wd, reducing wear and tear on the drive train.
The disadvantage of the manual hub is that yes, you would have to get out and engage your hubs for your 4wd to work. But again, this has absolutely nothing to do with your Automatic Differential Disconnect (ADD).
Let's look at it this way. If you have a "full time hub" like the 2nd gen 4runner the front drive train is constantly in motion even in 2wd. This not only increases wear and tear it also increases resistance, thus decreasing fuel efficiency, etc. When you're NOT in 4wd, the ADD system lets the axle spin, since they are always engaged, but it disconnects them "in a sense" from the differential. When you engage 4wd there is a vacuum activated system that connects the axles to the differential, thus the power from the transfer case can get to the wheels.
This is sort of a version of an automatic locking HUB, but not a locking differential.
__________________
Gibby
1994 4Runnner
39x13.50 IROKs
upndair is offline
Old 03-12-2003, 07:21 AM   #15 (permalink)
Stump1883's Avatar
Send a message via AIM to Stump1883
Okay I have been meaning to ask this for awhile now. What in the world is the ADD system? Sorry if that is a stuid question, I'm 2WD and I'm pretty sure that the ADD system pertans to 4WD systems. Thanks.
EDIT: Sorry about that questions above, good ol' AOL, just now loaded all the responses to this post, so now I can read them all and get a pretty good idea of it all. ADD is nothing more than just the Autmatic Locking Hud System right?? Is there anything else I'm missing here orould anyone like to "ADD"(very punny, not really I'm jst an idiot) something to my understanding. Thanks again.
__________________
97' 4Runner LTD
-With a few toys
Stump1883 is offline
Old 03-12-2003, 11:15 AM   #16 (permalink)
BajaTaco's Avatar
Here is a link...
http://www.off-road.com/toyota/tech/add/
__________________
Chris Marzonie
BAJATACO.COM
Adventure reports
Lots of Photos
OVERLAND JOURNAL
BajaTaco is offline
Old 03-12-2003, 05:44 PM   #17 (permalink)
4x4CPOSEADOG's Avatar
Send a message via AIM to 4x4CPOSEADOG Send a message via Yahoo to 4x4CPOSEADOG
Or try this link......
http://www.4x4wire.com/toyota/tech/add/
Noel
__________________
Noel
94 4Runner, V6, 4x4
97 LX450 (stock & no lockers) CDL'ed w/ Pin 7 Mod, Slee cupholder, OME lift soon......
04 Tacoma Ext Cab V6 4x4 TRD w/RR DIFF LOCK
4x4CPOSEADOG is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
bilstein 1500 shocks on stock taco rear end? alanbobalan 95.5-2004 Tacomas & 96-2002 4Runners 5 02-13-2006 11:14 PM
question about bring rear end back to stock dewey 95.5-2004 Tacomas & 96-2002 4Runners 2 10-20-2005 04:22 PM
Going back to stock - Need stock front bumper Ranski 95.5-2004 Tacomas & 96-2002 4Runners 2 09-14-2005 11:05 AM
front end higher than the back end? Allyia 95.5-2004 Tacomas & 96-2002 4Runners 10 07-20-2005 12:44 PM
94 LC front/rear lockers and 4:56 gears installed Biff Early Land Cruisers 23 06-15-2005 12:23 AM
2009 InternetBrands, Inc.
