front end shake
Old 09-16-2014, 04:35 PM
Polaris2012's Avatar
front end shake
I have a 2003 tacoma TRD with 82,000 miles v6 manual. At 65-75 mph it has a shake in the front end i can also feel it in the steering wheel. It more of a shake then a vibration. Its worse when im going straight vs when im on a slight turn. Any thoughts on what it could be? Im not familiar with these front ends. ball joints dont feel like they are bad. it has new shocks and struts and new wheels and tires (about a year old) had the tires balanced and it didnt help at all.
Old 09-16-2014, 05:15 PM
JasonYota's Avatar
Did you try rotating the tires to see if it stopped?
Old 09-16-2014, 05:18 PM
yes I had them balanced and rotated and it didnt change
Old 09-17-2014, 05:00 AM
JasonYota's Avatar
How about the alignment? Everything else is just about covered
Old 09-18-2014, 06:52 PM
JustinD's Avatar
check the bushings on the steering rack and sway bars.
Old 09-18-2014, 08:37 PM
Kiroshu's Avatar
X2 On possible worn/damaged steering gear mounting bushings.
Verify any excessive play in front steering/suspension parts.
Loose fastners..?
Loose wheel nuts..?
Flying91
45
04-11-2024 04:39 PM
jasonty
41
12-23-2018 01:00 PM
Daneums
08-20-2015 05:36 AM
88sasturbotoy
08-11-2015 01:56 AM
v_man
07-23-2015 04:01 PM
Quick Reply: front end shake
