Front end Sagging(ARB bumper), what Springs to get
I just bought a 2000 Tacoma 2.7 4x4 reg. cab, i really like the truck my only problem is the front end seems to sag a little, it has a ARB bumper which im sure is why its sagging. What can i do to help this problem, this is my daily driver and i want to handle good still. Im thinking of getting some OME springs but what kind should i get? Can i use those with factory shocks? Also would putting stock springs off a 3.4 tacoma help are the stiffer? thanks
Well.. It doesn't sound like you want to lift it.. If so I'd recommend OME 882's,
You can go with some 881's and probably be back to stock height.
You shocks are probably worn too, so just buy some OME shocks while your doing the whole thing.
Could you? Sure.
Is it recommended? No.
The valving in all of the other shocks is not going to match the spring rate of the OME springs.
Do it once, do it right.
I would go with the 883 over the 882s. The 883s give you almost as much lift as the 882s but they have a higher spring rate and won't sag like the 882s tend to.
FOG
FOG
check out NWOR's website, they have some shnazzy 'racing' suspension and a luxury ride suspension for front and rear; they do add about 2.75" up front but they claim they are 0-3" adjustable; I plan on buying the racing suspension for mine and trying them out as I don't want much if any lift, the guys I talked to at NWOR seemed to know a good deal about their stuff, worth a call. Might be too much for you but it will take care of any sag and improve handling quite a bit for sure.
yeah, NO spacers... and get new shocks!! bilsteins have a proven reputation; $300 bones for 4.
OME might be the route I go in the end though...
Prepared to lift the rear too?
Buy from Gooverland or Wheelersoffroad
NOTE: 882 and 883 coils require matching OME 90004 front shocks
Coils: http://www.toyteclifts.com/index.php...mart&Itemid=72
Shocks: http://www.toyteclifts.com/index.php...mart&Itemid=72
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
Vargntucson
07-04-2015 12:15 PM
