YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-29-2004, 05:48 PM   #1 (permalink)
Send a message via AIM to jkirk
Front end noise
I have a 94 4x4 pickup with some front end noise between 30 and 45 miles per hour that seems to be coming from the front passenger wheel. Kind of sounds like when you go over the small speed bumps right before a stop sign. A whoomp, whoomp, whoomp sound but no real vibration. I thought it was the old tires, so I bought new ones, the problem still exist. The manual hub doesn't quiet go into the lock position could the hub need re-built? I also put on a brand new rotor, caliper and set of pads. The only thing I can think of is the hub or bearings. Any one else have this problem before or have any suggestions?
jkirk is offline
Sponsored Links
To remove this ad, register today!
Old 08-29-2004, 07:53 PM   #2 (permalink)
Look at the hub noise posting, http://www.yotatech.com/showthread.php?t=27867. I have a similar problem, but it feels like I have some vibration. It stops after I hit 50mph.
__________________
98 4Runner SR5 V6 4WD, stock with a lot of dreams for my Runner. So much to do, so little money............ Oh yeah, the elbow mod. I live in NYC. With all the bumps and potholes, I don't have to go off-roading.
havic is offline
Old 08-29-2004, 09:05 PM   #3 (permalink)
Sludge's Avatar
Send a message via AIM to Sludge
Check your tie rod ends and ball joints. I get a small clunking sound from the front passenger side when i just about come to a complete stop. When I wiggled the front tire i get that same noise and have alot of slop in the front end.
__________________
92 4Runner SR5
Aisin hubs,pin stripe removed,police scanner,brush guard,Monroe Senseatrak shocks and steering stablizer,Brembo rotors,Downey HD coils,Blue reverse indiglo guages. . .
http://community.webshots.com/user/sludg3
Sludge is offline
Old 08-30-2004, 04:43 PM   #4 (permalink)
Yea I saw that thread, I was kind of thinking that the front bearing might have some problems with it. I had a local mechanic do my brake job to pass inspection. I guess I'll check my tirerods and easier parts before I decide to tear it down and get it fixed.
Thanks,
Jason
jkirk is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
front end noise? Yota Runner 86-95 Trucks & 4Runners 5 06-10-2006 06:30 PM
Front end noise...help, thanks Swissdrums 86-95 Trucks & 4Runners 9 04-05-2006 01:20 PM
Front end noise slustan 95.5-2004 Tacomas & 96-2002 4Runners 8 12-17-2004 08:00 PM
Front End Noise Cebby 95.5-2004 Tacomas & 96-2002 4Runners 5 02-09-2004 04:19 PM
Front end noise Cebby 95.5-2004 Tacomas & 96-2002 4Runners 2 12-30-2002 10:18 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
