YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 11-24-2003, 05:37 PM   #1 (permalink)
Front End Noise
I could use some help with a problem on my '91, 3.0, 5spd 4WD 4Runner that recetly developed.
I've got a very loud rubbing or grinding noise coming from the driver side front wheel area. Sounds much like a rubbing tire, but more metallic. This condition is not constant, but will present at any speed and in any gear, driving straight or turning. If it happens when driving straight, turning the wheel either direction slightly, will change the pitch and timbre of the noise. The noise did not appear over time, it went from not there to VERY loud overnight. Also, occasionally the vehicle will shudder violently for a fraction of a second, as if I hit something or ran over a good sized rock. When that happens the RPMs go down, as if an additional load is instantly put on the motor. It feels as if something is trying to engage that shouldn't. I'm also thinking that these two problems are related.
Otherwise the drivetrain seems fine. Motor runs great, tranny shifts fine, clutch is positive, transfer shifts smooth as well. I'm leaning toward a problem with CVs, U-joints, wheel bearings or the automatic hubs. There's definately some mechanical interference somewhere. Any ideas greatly appreciated. TIA.
HammerDown6 is offline
Sponsored Links
To remove this ad, register today!
Old 11-24-2003, 05:42 PM   #2 (permalink)
rpeAMP's Avatar
Send a message via ICQ to rpeAMP Send a message via AIM to rpeAMP Send a message via Yahoo to rpeAMP
How many miles? Sounds kinda like wheel bearings or CVs to me as well...
__________________
Preston Edwards
1992 4Runner SR5 V6 4WD (5 Spd.)
246,000 miles & counting
2" Downey coils, 32x11.5x15 BFG A/Ts, Rockcrawler Series 51 wheels, Magnaflow exhaust, Yakima roof rack, ARB bull bar, SAW Torsion bars, (4) PIAA 520s, Cobra 18 WX ST II CB w/ Firestik antenna, hp iPaq GPS
2007 Toyota Tacoma TRD Sport 4WD (5 Spd. Auto)
400 miles & counting
rpeAMP is offline
Old 11-24-2003, 06:37 PM   #3 (permalink)
150,000 and change.
I'm in the process of moving, so it'll be a couple days before I can get under it. Inspecting U-joints is easy. For CVs, is there any other test besides jacking up the vehicle and rotating to test for binding?
Old 11-24-2003, 06:44 PM   #4 (permalink)
Cebby's Avatar
Send a message via AIM to Cebby
Sounds like you might be down to the wear indicators on the brake pads. Get it checked ASAP. I let mine go a little too long and had to get (another) set of front rotors... :pat:
__________________
UZswap.com
A site dedicated to sharing info for swapping the Toyota/
Lexus UZ (V8) engines into Toyota Trucks and 4Runners.
My 4Runner
1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys,
low lift, hacked fenders, tubbed firewall, custom armor
TOOLandFAB.com
A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion
Cebby is offline
Old 11-24-2003, 06:46 PM   #5 (permalink)
It's not the brakes, I replaced them all the way around just before hunting season. 100% sure they were replaced correctly. Thanks though.
BTW, the noise isn't a high-pitched scaping noise. It's more of a dull metallic thump.
Old 11-24-2003, 06:56 PM   #6 (permalink)
Cebby's Avatar
Regarding your hubs, if it's the ADD system, you can rule out the hubs. The ADD system just uses a plate with no moving parts at the hub.
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 11-26-2003, 06:49 AM   #7 (permalink)
I don't believe that it's the ADD system, just the standard automatic locking hubs. (Or is that in fact the same thing?).
Old 11-26-2003, 08:19 AM   #8 (permalink)
Cebby's Avatar
Should be the same thing. Does the cover on the hub say "Automatic Disconnecting Differential"? If so this is the ADD system.
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 11-26-2003, 08:31 AM   #9 (permalink)
Staff
UKMyers's Avatar
Send a message via AIM to UKMyers
Wheel bearing maybe?
__________________
2006 Tacoma TRD offroad 4.0 Access Cab 6 sp 3" Revtek, 285 BFG's, Borla Catback, Volant Intake, Billet Grill, Split Second PSC1 Professionally dyno tuned, URD Short Shifter Kit, 226 RWHP
1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's See my build up thread here http://www.yotatech.com/showthread.php?t=104000
Quote:
where on the 3vze manual is the transmission dipstick?
Quote:
what is sas?
UKMyers is offline
Old 11-26-2003, 09:04 AM   #10 (permalink)
cv's. relaced my left side 2x in 165,000. the first time i heard the clunking/grinding noise and sure enough, the boot was busted. must have been that way for awhile and got all sorts of grit inside.
2nd time, last month, i noticed the boot was busted, so i replaced them before the cv joint got bad.
i believe mine to be prone because i make a lot of u-turns. so i got the manual hubs to save the cv wear-and-tear.
BTW, i've never replaced the passenger side. boots still look good.
but if you're driving in 2wd, it won't be the u-joints, and shouldn't drop the RPMs (if it IS the cvs).
__________________
95 4Runner 3.0 auto ~ 170+K and still ticking...
Downey springs and Monroe Sensatracs
31" BFG AT/KO
Aisin manual hubs
nofilter is offline
Old 11-26-2003, 09:07 AM   #11 (permalink)
Cebby's Avatar
Quote:
I've got to ask why??? Being chased?
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 11-26-2003, 09:12 AM   #12 (permalink)
Upon inspection, the cover does say "Automatic Disconnecting Differential".
I am starting to suspect a wheel bearing, as the sound semms to be located more outboard than inboard. As I understand it, with the IFS and ADD systems, the CV shafts are constantly rotating while the vehicle is in motion. If that is the case, then when shifting into 4WD, the engagement would occur at the inboard side between the front diff. and the CV, correct? So what is it that keeps the CV disengaged under normal conditions? Could there be a component here that can fail and allow the CV to try and lock in to the front diff.? Of couse, in 2WD, the front diff. isn't rotating anyway, but could the CV be trying to hook up to a static gear?
Old 11-26-2003, 09:14 AM   #13 (permalink)
have you ever tried to park in san francisco? everything is street parking, and the 4runner won't fit in a lot of spaces (if you overhang a driveway, the residents will have you ticketed or towed). so if you see one across the street, you flip it quick or drive around for another 30 minutes looking for a space 3 blocks away from where you want to go!
there's a write up in 4x4wire i think about defeating the ADD vacuum system. you could try this, to eliminate the axle-diff source as problem.
you could jack the wheel up, and spin it to see if it;s bearings, brakes, or cv. are your boots intact?
__________________
31" BFG AT/KO
Aisin manual hubs
nofilter is offline
Old 11-26-2003, 09:26 AM   #14 (permalink)
Cebby's Avatar
The manual hubs will keep the CV's from turning all the time. Easy and cheap. You can get of Aisins for under $50 and it's easy to do yourself.
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 11-26-2003, 09:34 AM   #15 (permalink)
Thanks for all the input guys. As soon as I get into the new house, I'll be able to further inspect the vehicle. I have a set of Aisins ready to go on the bench as well. If the problem turns out to be a wheel bearing, I'll be able to take care of both at once.
Old 11-27-2003, 08:20 PM   #16 (permalink)
Can't recall exactly what they are called but there is a bushing inside the hub that the shaft rides in. There is a replacement that is roller bearing if I recall correctly. I have not had to do these yet but I have read posts indicating others have had this problem.
Edit - check here
http://www.yotatech.com/~corey/tech/...imrockford.htm
oldsub86 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
front end noise? Yota Runner 86-95 Trucks & 4Runners 5 06-10-2006 06:30 PM
Front end noise...help, thanks Swissdrums 86-95 Trucks & 4Runners 9 04-05-2006 01:20 PM
Front end noise slustan 95.5-2004 Tacomas & 96-2002 4Runners 8 12-17-2004 08:00 PM
Front end noise jkirk 95.5-2004 Tacomas & 96-2002 4Runners 3 08-30-2004 04:43 PM
Front end noise Cebby 95.5-2004 Tacomas & 96-2002 4Runners 2 12-30-2002 10:18 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
