Front end help
Old 11-22-2008, 11:48 AM
kawicowboy's Avatar
Front end help
Ok so in an earlier thread I posted I picked up a 96 Taco V6 4x4, there is some serious wear on the front tires, both are worn on the inside, Ifigured it was the ball joints but when I jacked it up there was no play that I could tell from side to side and up and down however I did notice that the bottom bushing on the strut might be gone. I stuck a prybar in to move the strut up and down and you could see that there is a lot of movement where the bottom of the strut is bolted in, its sits off center so Im pretty sure its gone just wanted to confirm this.
Old 11-22-2008, 11:52 AM
Staff
DeathCougar's Avatar
You might check your upper ball joints. If the inner portion of the tires are worn, its from the tires leaning in
Old 11-22-2008, 12:38 PM
kawicowboy's Avatar
So you dont think its suspention related
Old 11-22-2008, 01:40 PM
Staff
The upper ball joint is part of your suspension.
When was the last time you had it aligned?
Old 11-23-2008, 10:20 AM
kawicowboy's Avatar
So whats the proper way to check a upper ball joint.
Flying91
45
04-11-2024 04:39 PM
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
Daneums
08-20-2015 05:36 AM
88sasturbotoy
08-11-2015 01:56 AM
Quick Reply: Front end help
