Front Brake Upgrade
Front Brake Upgrade
My front rotors are warped pretty bad, I'm about sick of the shaking steering wheel when I stop. I am looking for some rotors that will withstand the heat better then OEM, along with some new hawk pads. I also thought about picking up some braided brake lines as well. Any suggestions to what I should use for rotors and lines?
ive heard good things about ebc brakes... definately get drilled if you can...
my brakes do the same thing, but they squeak reallly bad... i need to get some money to do that...
check out autopartswarehouse.com for rotors..
I've heard that drilled are prone to cracking, but then slotted rotors will get mud stuffed in the slots. Ya, mine are squeeking too, there's plenty of pad left, don't know what the squeekings about, but that and the shaking are driving me crazy.
brembos are a good choice and go well with the hawk pads
you can get crossed drilled or blanks, let someone chime in on which is better for the setup
ss stainless steel brake lines would be the best bet, i think toytec sells them they're just not displayed on the site
My recommendation:
1. Brembo blanks
2. Stock pads
3. Goodridge SS brakelines - Best price at: http://www.hrpworld.com/index.cfm?fo...action=product
4. Adjust your rear drums. Otherwise your front rotors do all the work to stop our overweight trucks - increase predisposition for warping. Search for the thread.
Crossdrilled/slotted - Once useful at ventilating outgassing. Not necessary unless you do some serious racing, and even those that do, there are pads today that allow efficient heat ventilation. Crossdrilling will decrease the weight of the rotor, which will make it heat up faster, (think a small metal pot vs. a heavier metal pot... Which will boil water faster?), and result in "stress risers." Slotted will give you a fresh pad surface every time you step on the brake... which may or may not improve braking, but will force you to buy pads more often. In conclusion, crossdrilled/slotted rotors are pretty much only for aesthetic purposes. If you think they're sexy and have an extra $20 per rotor to spend, go for it.
Off of the Baer FAQ:
"Will slotting or crossdrilling my rotors improve my car's stopping performance?
DEFINITELY NOT! Crossdrilled or slotted rotors do produce a strong visual appeal behind a modern open wheel, and they do have a performance edge when pad outgassing occurs. Outgassing occurs at extreme temperatures when the bonding agents that hold the pad material together break down into a gas form. This gas creates a pneumatic barrier between the rotor and the pad, reducing friction. Crossdrilling or slotting creates a path for the outgassing that occurs during extreme braking conditions. However, these conditions can virtually never be reached on the street! Short of a complete system, performance brake pads, a proper Teflon lined braided stainless steel hose set and quality brake fluids are the only direct replacement upgrades that can be combined to deliver measurable stopping improvements in the context of direct replacement components on the OE brake system."
www.baer.com
Go to baertech, then to F.A.Q, (frequently asked questions)
1. Brembo blanks
2. Stock pads
www.baer.com
I never had a problem with my X drilled and slotted Brembo rotors . they are great , I can go from 80 to nothing with out break fade. I am using Napa pads . For me the best investment after the S.C.
OEM rotors will just warp again... that is the problem in the first place.
I went with Brembo slotted and OEM pads. 25k miles on the set and they aren't even half worn. I towed a 4000lb trailer across the USA and have no warpage. If I did it all over I'd just go with Brembo blank rotors.
I had considered doing the Tundra upgrade, I even had the parts, then wondered why I was going to change when my current setup is working fine. I sold the Tundra parts.
I was talking about OEM tundra rotors
so slotted rotors actually work? and for brakes i plan to use raybestos... the mechanic who did my last brake job used some shoddy nonbrand brakes.. yet theyre still at 80%, and i got it done in march.. so he must have done something right......
Please excuse my ignorance as I have never done a brake job, but, would it be a bad idea to only replace the rotors (I have about 50K miles on my pads and rotors) and leave current oem pads. As a total novice, it would seem very easy to replace rotors (as many have recommended Brembo blanks with oem pads) and not have to worry about bleeding, etc. I have seen that some get their brake pedal screwed up afterwards. Or, if you're pads have been rubbing on warped rotors, will it mess up the new ones? Thanks in advance.
Can you change rotors withou changing pads? In short, yes. And I've done it, but only on junk cars or something I was going to sell immediately. Read on. To echo guapo's post, you should change the pads when changing rotors. A few reasons why.
1. A pad will wear along with a rotor, sometimes more obvious to the eye than others. When you change the rotor and install a worn pad, you will not get 100% friction surface initially, and when it does wear in it will be uneven.
2. If your current pad is 50%, why risk wearing it down to metal and scrapping out your new rotors prematurely?
3. Changing the pad does not require brake bleeding. The only extra step besides physically pulling the pad out and replacing it is pushing the piston back into the caliper, usually using a C-clamp. There is no reason to open the brake line during this process, thus eliminating any need to bleed.
Thanks for the replies. I've mostly read about the Tundra upgrade and wasn't sure I wanted this to be my first attempt. I understand now that the bleeding was due to caliper replacement. Replacing oem rotors and pads seemed a little more doable, and if I don't have to bleed, I think I'll try this first.
Piece of cake. But for a first timer I would recommend having an experienced friend oversee your work, since brakes are a major safety issue and shouldn't be taken lightly as we often do.
Just go Brembo as far as rotors. You'll be glad you did.
