front axle change out
Old 01-03-2014, 04:47 AM
bird1dog's Avatar
I have a 97 tacoma with a loose front pinion shaft and was thinking of just swapping the whole ifs axle from a junker for now till I can build this one and change gears.
What year donar trucks do I need to look for for a bolt in swap?
Thanks for any help. I have early 90s toys but this is the first 4th gen for me.
This is a 2.7L reg cab.
Old 01-08-2014, 06:03 AM
bird1dog's Avatar
Anybody know if a 96 3.4 v6 auto w/lockouts used the same gear ratio as a 97 2.7 4cyl 5 speed w/lockouts from the factory?
Can you tell from the vin?
Thanks in advance.
Old 01-08-2014, 06:07 AM
HighLux's Avatar
best way to find info on this site is to search...but do it like this...
type something like "ifs diff interchangability tacoma yotatech" in google.
try that. I doubt alot of people are going to look up these basic questions for you. Try searching like I suggested above.
Old 01-08-2014, 12:02 PM
reaj's Avatar
Best way to search the VIN on a parts website it will give you axle ratios, more then likely you will need both vins. Not 100%. But I believe the 4cyl and the 6cyl axles are different IE strength and what not! Good luck!
Old 01-08-2014, 07:04 PM
bird1dog's Avatar
Thank, can't get the other vin though. Thought the fronts were both 7.5s and the rear was where the larger diffs were. I'm only familiar with the early 90 models. Hoped someone would know if they used anything other than 4.10s while the deal was in front of me. Could have grabbed front and back I guess and gotten the heavier rear as well. Prob end up pulling this one and driving it as a 2wd while I build it. That way I can go ahead and add a locker or just spool it.
Eggslinger
06-08-2019 03:32 PM
jerusry
10-19-2015 05:28 PM
madxman21
07-09-2015 10:26 AM
ItsJustD
07-07-2015 07:49 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: front axle change out
