Found some LC's.
Old 09-27-2007, 04:43 AM
Nate08's Avatar
Found some LC's.
I found some from a 97 LandCruiser but the only have 6 wraps . I can get them for $40 plus shipping. What do you guys think?
Old 09-27-2007, 07:24 AM
Ron Helmuth's Avatar
I thought I had heard the 1996 coils were the ones to have....but I have been wrong before....
Old 09-27-2007, 07:31 AM
emptypockets's Avatar
Mine are the shorter coils and are from a '95. I've never heard of a 6 wrap LC coil...IIRC, mine are the 7 wrap model. Hope someone else can chime in with some answers about the ones you're looking at. I got mine brand new for ~$120 shipped and I used the Toyota part numbers I found here at YT.
Old 09-27-2007, 07:49 AM
frodin1's Avatar
What are the color codes? When I was shopping for mine, I was told 95 and earlier is what to look for, otherwise they're way to long. If you want alot of rake it doesn't matter.
Old 09-27-2007, 07:54 AM
Nate08's Avatar
They are Double Yellow - Yellow. and Double Pink Yellow.
Old 09-27-2007, 01:08 PM
Nate08's Avatar
Here is a pic of them. The guy said the front ones for sale were the ones pictured...let me know what you think. I think they'd prob give about 3" to 3.5" of lift. 114K on em.
Old 09-27-2007, 01:34 PM
Jdizzydub's Avatar
I got mine off of a 97' also, but they've got more wraps.
And this is the how much rake I got and I actually didn't mind it.
Old 09-27-2007, 03:43 PM
Nate08's Avatar
How mh lift do you have up front?
Old 09-27-2007, 06:14 PM
sschaefer3's Avatar
Those don't even "look" right. Those are not from an LC, they are from something completely different. The bottom of the coil should be completely flat. These are not LC coils at all.
Old 09-27-2007, 07:24 PM
MillerPKA's Avatar
what steve said, there should be a plateau on the bottom to sit properly on the mounting plate....hold on let me dig up a picture of mine
Old 09-27-2007, 07:28 PM
MillerPKA's Avatar
lc's are on the left, 890s on the right
wait.........you didn't get the rear coils did you?
Old 09-27-2007, 07:32 PM
sschaefer3's Avatar
Those are LC coils but not even close to the ones we use. Those are way taller.
Old 11-15-2007, 09:02 AM
MillerPKA's Avatar
Steve, I was browsing your site and you have the exact same coils pictured with your system 1 kit. I didn't revive this to put that in your face, rather to get a part number off of you if you have it
Old 11-15-2007, 11:02 AM
sschaefer3's Avatar
Both of the rear coils we use have the color codes of:
Double Purple + Gray + White
Old 11-16-2007, 02:25 PM
rootedtree's Avatar
3.5" lift too much for stock stocks?
Can you run these coils with a stock shock, or are they too short? Thanks
Old 11-16-2007, 02:33 PM
yotasavg's Avatar
stock shocks will most likely be too short. they may work but they'll limit droop.
Old 11-16-2007, 02:35 PM
MillerPKA's Avatar
yeah you'll be fine, i'd recommend at least pro comp es1000s in the near future though (70 bucks/pair)
Old 11-17-2007, 09:20 AM
rootedtree's Avatar
Also, I seem to be reading conflicting information......is it the Front or the Rear LC coils that we're after for our application? Thanks
Old 11-17-2007, 09:28 AM
MillerPKA's Avatar
front cruiser coils for our rear
shisha1999
08-14-2015 01:33 AM
bighaydn
08-04-2015 07:17 PM
irritech
07-27-2015 05:15 PM
yourrealdad
07-21-2015 11:13 AM
msane99
07-17-2015 10:13 AM
Quick Reply: Found some LC's.
