Found in my oil pan
Old 07-18-2015, 05:06 PM
irritech's Avatar
Found in my oil pan
New to the forum but have stalked you guys for years. 98 3.4l 2WD. Bought it 3 years ago with 172,000 miles now has 222,000. No issues with it at all in 3 year. my daughter is headed to school with it this fall so II needed to do a few things. Valve cover gaskets, timing belt and oil pan gasket. Both valve cover and oil pan were leaking. popped the oil pan off this evening and found this in the bottom of the pan. Any ideas?? I have not removed the strainer or baffle yet, kinda stunned when I found this.
Old 07-19-2015, 02:25 AM
wyoming9's Avatar
Red face
It almost looks like a part of the thrust washer but hard to say from the picture.
Old 07-22-2015, 02:21 PM
aowRS's Avatar
How about placing a coin next to the item (or some other item for size reference)?
Andreas
Old 07-27-2015, 05:15 PM
irritech's Avatar
ok, it is definately a thrust washer. I did the valve cover gaskets, intake manifold gaskets, etc. this weekend and the next door neighbors kid came over. Turns out he's been rebuilding 22re engines for a couple of years. Knew exactly what it was. So, morally I can't sell it so I guess I'm going to have to pull the crank and replace the bearings and washers. Anyone have a thread that runs through this??
bigjstang
08-25-2021 12:41 AM
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: Found in my oil pan
